EDFC Wiring Question
Where did you guys hook your red, yellow, green, and ground wires to? I don't really know anything about wiring, and this is the last part I need to do to get my EDFC running. Thanks.
There is a wiring diagram in the install directions that clearly identifies each wire by color but if you are asking that question I would stop and bring it to a shop to do the wiring for you. It is pretty simple and should not take a qualified shop more than a few minutes to hook it up. A good car stereo shop could do it for you.
If I recall there is a power lead that hooks to ignition, a power lead that hooks to an always on power source, an illumination dimmer wire (I didnt hook that one up), and a ground. I could get you the color codes tonight if you dont have the diagram.
I think I am capable of doing the wiring myself, I just need to know if the colors match up and what wires would provide enough power. I have the ground wire done, I just want suggestions on the other ones. I would like to hook it up to my aftermarket radio harness, but if I remember correctly the colors don't match with the ones for the EDFC.
Originally Posted by 35ounces
You can not connect them strictly by color!
04-04-2016 07:52 AM
