Alignment results after Hotckis install
Old May 14, 2005 | 07:07 AM
brendone's Avatar
brendone
Default Alignment results after Hotckis install
FYI to anyone installing Hotckis Springs, here are my alignment before and after results from the dealer yesterday. Everything except for front and rear camber was brought back within spec. The tech noted the lack of camber adjustment for the front, and the rear is at max adjustment. <_< Looks like adjustable camber might be a good addition at some point.
I waited a couple weeks after install since the springs do settle over time. Right after I installed these, there was zero drop front and back. After two weeks, the front has dropped the 1/2" hotckis specifies.
Old May 16, 2005 | 09:37 AM
JimRHIT's Avatar
JimRHIT
Mine ended up at
Front
L R
-0.6degrees -0.6 degrees
toe
0.00 0.00
Rear
-1.5degrees -1.5 degrees
toe
0.05 0.05 (total 0.10)
This was with the SPC rear kit and Performance Nissan front A-Arms
I must say, you did much better on the alignment than I did before these additions. Good luck with the innner tire wear-ing...just keep an eye on it and cross rotate when necessary. I didn't and went through my Toyos a lil faster than I would have liked.
- Jim
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
