10.5 +24 offset camber and toe
Old Jun 29, 2005 | 10:33 PM
mono11's Avatar
mono11
Default 10.5 +24 offset camber and toe
what r the camber and toe specs: on a 10.5 +24 offset (rear) i 'm starting to get fethering in the inside of my wheels and nissan and firestone have the same stock specs. nisssan only adjust it with factory specs: firestone has the same specs but they r willing to adjusted the way i want it the only thing is that i need the toe and camber setting for the size of wheels i have on. please help... thank you
Old Jun 29, 2005 | 11:30 PM
mono11's Avatar
mono11
Default help please
this s what i installed what else do i need?
http://kinetixracing.com/index.asp?P...&ProdID=4&HS=1
Old Jun 30, 2005 | 12:40 AM
JETPILOT's Avatar
JETPILOT
Wheel/tire size doesn't affect camber/toe settings. Factory specs unless for some performance reason you want something else. If not go with factory spec.
Respect
JET
Old Jun 30, 2005 | 06:57 AM
mono11's Avatar
mono11
humm then why am i getting tire wear in the inside and my tires look like this
// \\ from behind?
Old Jun 30, 2005 | 07:12 AM
JETPILOT's Avatar
JETPILOT
Did u lower the car?
Respect
JET
Old Jun 30, 2005 | 11:30 AM
mono11's Avatar
mono11
i bought it like that if anything mabe like 1 "
Old Jun 30, 2005 | 11:41 AM
Zivman's Avatar
Zivman
With the Z, you will get uneven wear on the tires due to negative camber and being unable to rotate the tires. They will wear from the inside first do to the stance being : / \
I am running a very neutral rear camber at -1.6 degrees. You can get down to around -1.1-1.3, but you will still wear from the inside out because negative camber is still present.
FYI: a 1" drop on the Z is a pretty significant drop and without the adjustable camber arms, you wouldn't be able to allign to stock specs.
Old Jun 30, 2005 | 01:10 PM
mono11's Avatar
mono11
so best thing to do is like tell firestone to like adjust it a lil wher my wheels r not that much // \\ and see what happend worse come to worse i just put it the way it was (factory). what do u think?
Old Jun 30, 2005 | 07:07 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
tire/wheel combo absolutely affects your alignment....common sense really. The alignment is done with the wheels on the car....so, as you alter width, tire size and offset, you are totally changing your alignment settings
If you need to readjust your rear camber and toe, the SPC set is the best bet
Old Jun 30, 2005 | 08:11 PM
mono11's Avatar
mono11
i got that installed i guess i just need the toe bolts. but the main questiion how much do i need to adjust on camber and toe i heared toe has to be at 0 . i wish some one would post what setting r they running with my same set up. 10.5 offset +24
Old Jun 30, 2005 | 08:45 PM
Zivman's Avatar
Zivman
Your wheels and offset have no bearing on what specs to run. Your wheel and offset MAY impact if you are able to get to stock spec. Just get as close to stock spec as possible.
Old Jun 30, 2005 | 09:18 PM
mono11's Avatar
mono11
k thats what i have now i guess i'll start saving for a new pair of rear wheels lol!!!... thanks
Old Jul 1, 2005 | 03:48 AM
Zivman's Avatar
Zivman
For what reason? You don't seem to be understanding the concept at hand
Just take your car to the allignment shop and tell them to get it within spec
Old Jul 1, 2005 | 04:47 AM
Z1 Performance
Former Sponsor
this is what you need to do:
1. buy the adjustable toe bolts
2. have them installed
3. have your alignment shop then relalign the car back to stock specs
4. have fun
there is no reason on earth for you to buy new wheels...you simply have to buy the other half of the equation (in this case the toe bolts) to make the rear of the car adjustable
Old Jul 1, 2005 | 06:41 AM
JETPILOT's Avatar
JETPILOT
1.0 negative camber is 1.0 degree negative camber is 1.0 degree negative camber no matter what wheel tire combo you are using. Same as toe setting. Common sense really. All factors being the same as far as tire surface wear.... you can put any combination of wheel witdh, tire size and you alllignment numbers will be as before. Guaranteed.
Respect
JET
Old Jul 1, 2005 | 07:00 AM
Z1 Performance
Former Sponsor
I guarantee you are wrong As you alter the size of the contact patch, you unavoidably alter alignment
Old Jul 1, 2005 | 07:02 AM
mono11's Avatar
mono11
k got it i'll just leave it the way it is . right now it has factory specs.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
