What is needed to fix Brembos from track to touring?
Old Jul 4, 2005 | 09:42 AM
Bahraini350Z's Avatar
Bahraini350Z
Default What is needed to fix Brembos from track to touring?
Friend totaled his Z and I want to know what are the parts I need to get the swap done Will I be needing the brake lines as well or can I do without them??
Thanks
Old Jul 4, 2005 | 10:21 AM
knicksinny's Avatar
knicksinny
you will need:
bolts for the rear calipers
brake lines (I would suggest upgrading the lines and buying SS lines)
Rear backing plates (You could just cut or modify the ones on your car)
westpak's Avatar
westpak
SFZCC
I would take advantage and get a set of SS brake lines, and all you need is to make sure you get the rear mounting bolts as they are different and you will have to remove or trim the rear brake guard to allow for the bigger rotor.
Old Jul 4, 2005 | 11:04 AM
Bahraini350Z
Ok, but can I just do with my stock brake lines?
Old Jul 4, 2005 | 12:08 PM
westpak's Avatar
westpak
SFZCC
You should be able to but the Brembo's are different, as the stock ones use a bolt with a fitting while the Brembo's screw into the caliper at the end of the line.
I say they should work because the Stoptech SS lines work on both stock and Brembo calipers although I like the way the Brembo lines screw in less chance for leaks the other type you have to use the brass washers to creat the seal.
Old Jul 4, 2005 | 07:41 PM
Bahraini350Z
thanks
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
codek
Sep 27, 2015 03:21 PM
