Info on track pads for you guys!
Old Jul 21, 2005 | 11:57 AM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Default Info on track pads for you guys!
I thought these might be good info for you guys so here it is:
Endless Pads
Super Street Sports
The rotor temperature range for this compound is wide and mu-level is consistently stable. Thus, brake pedal force does not change considerably at different rotor temperature ranges and braking performance levels maintain consistency on the street given most situations. This is a very controllable compound that is set at a high mu-level. After fade, recovery is achieved while brake performance does not worsen, returning to the mu-levels achieved before fade, right away. Part of the Non-Steel Series, Endless uses a Non-Steel Developmental Process using a new, mild ceramic material to increase rotor friendliness. With no steel materials, dust is minimal and rusting is prevented, enabling ease of cleaning wheels (even with water).
Driving Field: Street/Winding Road/Circuit
Appropriate Rotor Temp. Range: 32-932F
Type CCX
Proven to perform well on both street and track conditions, this original formula, ceramic carbon metal base compound has the ability to perform for a wider range of users. For the street where low temperatures are frequent, this pad performs well causing less damage than most semi-metallic pads. Usually, semi-metallic pads sacrifice initial response to perform better at higher temperatures, but the CC-X is able to do well at initial response as well. At higher temperatures, pedal feeling responds well while maintaining controllability with a stable coefficient of friction.
Appropriate Rotor Temp. Range: 210-1300F
Type CCR
Fade, brake controllability and braking force are kept in mind when developing this pad for the circuit. This pad was developed to improve and increase cornering speed. This pad allows "late braking" to increase corner speed. CC-R uses a new, special blend of ceramic carbon metal materials which has contributed in increased controllability. A balance of braking and tire grip is needed during cornering. This compound helps to achieve this while maintaining its rotor friendliness.
Driving Field: Winding Road/Circuit
Appropriate Rotor Temp. Range: 32-1500F
Tom
Gruppe-S's Avatar
Gruppe-S
Default Info on street/track pads for you guys!
PORTERFIELD
R-4 Full Race Compound
Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictably. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, oval track, rally, vintage racing, autocross, club events or professional racing events.
R4-E Endurance Race Compound
A carbon kevlar compound made to last a bit longer than the original R-4 compound. The R4-E compound is designed to endure higher prolonged temperature and still has pad life as long or longer than Porterfield R-4 do. This pad is great for club enduro events and applications where temperatures are at their maximum.
R4-1 Vintage Full Race Compound
Developed using knowledge testing in the vintage racing community. Optimum uses for the R4-1, under conditions where very high friction is needed with minimal warm up time and in applications where there is difficulty in maintaining sufficient heat with conventional race pad compounds. Widely used on vintage GT and formula cars the R4-1 is also gaining popularity in off-road and rally-cross classes. Great modulation, consistent pedal feedback and rotor friendly at all temperatures as with all the other Porterfield Carbon Kevlar compounds.
R4-S High Performance Street and Autocross
For high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers schools, solo events, and rally’s. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
RAYBESTOS RACING BRAKE PADS
ST41 – The best high energy input racing material available. Maintains high mu level at extremely high temperatures without sacrificing good wear – both pad and rotor. Needs some heat to work well.
ST42 – Lower mu than ST 41 and ST 43. Extremely stable average and in stop output over a wide temperature range. Has been very successful when used on the rear in conjunction with 41 on the front. Best high-temperature wear of all out materials.
ST43 – Friction level and wear rate between ST41 and ST42. Stability is not quite as good as 42 but better than 41. Should be an excellent open wheel formula. ST38 – Slightly lower mu than ST42. Wear still not as good as ST41. Good Performance over broad temperature range with minimal rotor wear. Successful in a broad range of racing series.
Old Jul 21, 2005 | 11:58 AM
Gruppe-S's Avatar
Gruppe-S
HAWK PERFORMANCE BRAKE PADS
HT-15 (R) – Very high torque with a smooth initial bite. Excellent linear torque to applied pressure relationship. Designed for cars with extremely high deceleration rates and limited down force. Temp Range 300F-1600F.
HT-14 (V) – Very high torque with aggressive initial bite. Excellent modulation and release characteristics. Designed for cars with extremely high deceleration rates and down force. Supercedes HT-12 material. Temp Range 300F-1600F.
HT-10 (S) – Intermediate to high torque with a smooth initial bite. Excellent modulation, consistent pedal, good release characteristics. Temp Range 300F-1600F.
Blue 9012 (E) – Medium/High Torque compound. Low pad wear with good brake modulation. #1 selling pad material for SCCA. Temp Range 250F-1000F.
Black (M) – Medium torque compound designed to be a good, all-purpose low-cost racing pad. Temp Range 100F-900F.
HP Plus (N) – HP Plus can take the heat at the track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast. Warning! Due to the dramatic friction levels produces by this product to achieve “Race Level” braking, rotor wear, noise, dust and pad life may be affected.
HPS (F) – HPS material provides advanced braking characteristics to enhance your driving experience. Gentle on rotors, virtually noise free, extremely low dust, and long pad life. HPS also offers better stopping power over O.E. pads.
HP Superduty (P) – This material is a unique blend of Organic, Carbon fiber & Ceramic materials offering unmatched performance under severe high inertia applications. This material is ideal for heavy-duty truck fleets, large SUV’s and P/U trucks. HP Superduty provides the durability, safety and performance to meet or exceed you application needs.
PERFORMANCE FRICTION BRAKE PADS
02 Compound – The newest PFC compound offering the highest friction level of all. This also features outstanding initial bite and with great modulation.
01 Compound – 01 has a high flat torque curve, providing excellent pedal modulation. Better pad wear than 83 and faster smoother release. Cold bite comes in at ambient temperature and is effective to over 1200F. 01 polishes the rotor without pad material build up.
99 Compound – Shares the same features as the 97 compound, but with slightly higher torque. These new advanced compounds improve both modulation and release. There is reduced torque rise with temperature with both 97 and 99 compound.
97 Compound – Has a bite slightly higher than 90 compound. Cold bite comes in at 250 degrees and has a moderate flat torque curve. With the flat torque curve the driver now has the ability to turn the steering wheel in the corner while braking. This compound also releases faster than all of the other above-mentioned compounds.
93 Compound – 93 was developed as the next step after 83. The improvements are better release characteristics, great improvement for trailing into a corner or modulation at threshold braking. Kinder to discs. 93 comes on quicker and has flatter torque curve. But, be careful without finesse you can over slow the car. When it comes to ultimate performance with finesse, this is second to none. Cold bite comes in at 250-275 degrees and has an effective torque curve over 1200 degrees.
90 Compound – 90 was developed at the same time as 93 and is very similar with lower torque output. It also has a higher wear rate under severe service. This pad gives three times the pad and rotor life, ultimate torque close to 93. Its modulation characteristics also make it forgiving. Cold bite comes in at 100 degrees and has an effective torque curve over 1000 degrees.
83 Compound – This material has super high torque and gives a firm pedal feel. 83 require finesse. Under sever conditions, it has outstanding wear characteristics. 83’s cold bite also comes in at 400 degrees and has an effective torque curve over 1500 degrees.
80 Compound – 80 is the lowest friction. It has very good wear characteristics and is more rotor friendly than 83. It is more suitable and therefore a favorite for many applications where pedal modulation is difficult or chassis set up or driver development brake balance or others require a more forgiving pad. Cold bite comes in at 350 degrees and has an effective torque curve to over 1000 degrees.
Z Rated Performance Street – The highest friction brake pad available for street vehicles. This is designed for customers who demand ultra high performance braking with low wear, rotor compatibility and fade resistance.
Highway Product – The highway product is recommended for trucks, vans, motor homes, suburbans, limousines, police cars, tow vehicles, and armored vehicles. This brake pad provides superior braking over stock and after market pads. Designed to wear long when used on heavy vehicles while still providing improved braking over stock.
Old Jul 21, 2005 | 11:59 AM
Gruppe-S's Avatar
Gruppe-S
CARBOTECH
CARBOTECH PANTHER XP10 (1110): For 2004, Carbotech unleashes Panther XP10 (compound 1110). This is an *extremely* high initial bite material, with a friction coefficient well above .6. Fade resistance is in excess of 1600F. Due to the high level of friction and bite, this material is recommended *ONLY* for cars in excess of 2600lbs using R-compound race tires or slicks (SCCA T1, T2, A Sedan, GT1, Trans-Am, Speed GT, etc.). On these heavier cars, 1110 still maintains the excellent modulation that has made the Panther-series of brake pads so popular. It is not recommended to drive this compound on the street or on the track with street tires due to the tendency to easily lock a lower-grip street tire with very little effort due to the high friction coefficient of this material. Note: Compound #1110 is more rotor aggressive than any other 1100-series compound.
CARBOTECH PANTHER XP9 (1109): Another iteration of our successful Panther compound series, 1109 offers even higher initial bite, higher friction coefficient (.6+), and higher fade resistance (1400+F) than 1108 compound, yet still maintains the rotor friendliness and streetability that has made the ceramic-metallic based Panther line so popular. This compound is intended for expert - instructor level HPDE drivers as well as upper level regional and national road-racing (ITA, ITS, Spec Miata, SSC, SSB, FF Cobra, etc) Panther XP9 has already won multiple SCCA regional and national championships in 2003, its first year of release. Not recommended as a daily-driving street pad due to possible elevated levels of dust and noise.**
CARBOTECH PANTHER XP8 (1108): A high torque brake compound with a wide operating temperature range (250F to 1350F). Outstanding initial bite at race temperatures, high coefficient of friction (0.58-0.60), excellent modulation and release characteristics, extremely high fade resistance, very rotor friendly and excellent wear rates. Excellent for ITA, ITB, Spec-RX7, etc race cars. Perfect for intermediate - advanced track/HPED use with R-compound tires, but still can be easily driven to and from the track. Not recommended as a daily-driving street pad due to possible elevated levels of dust and noise.*
CARBOTECH PANTHER PLUS (1106): A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range (150F to 1250F). Advanced compound matrix provides an excellent initial "bite", high coefficient of friction (0.54-0.56), and very progressive brake modulation and release characteristics. Panther Plus offers high fade resistance, rotor friendliness at all temperatures, and excellent cold stopping power. As a result, Panther Plus is an excellent choice for beginner-novice lapping day and high performance driver's schools on street driven cars using street or R-compound tires, eliminating the need to change brake pads at the track. Panther Plus has gained tremendous popularity with SCCA Prosolo/Solo2 competitors for its fantastic bite and modulation. In addition, Panther Plus has seen great success as a race-only pad on lighter improved touring and vintage race cars (ITC, etc).**Not recommended as a daily-driving street pad due to possible elevated levels of dust and noise.**
Carbotech Bobcat (1521) :the much anticipated replacement for our heralded Super Street F. Like our Panther line of compounds, Bobcat is a ceramic based friction material offering practically zero rotor damage. Bobcat offers outstanding performance when cold, very low dusting, and low noise with an excellent initial bite. Friction coefficient is .45 over it’s operating range of ambient temp to 900F. Bobcat is suitable for street, SCCA Solo 2 and Prosolo applications. Bobcat is not recommended for on-track driving schools or club racing.
CARBOTECH SUPER STREET-F (7266)
Super Street-F is a high-performance compound which far exceeds the capabilities of OEM brake pads.* Advanced compound formulation of the Super Street-F exhibits medium/high torque (coefficient of friction of 0.42), excellent brake modulation, low noise levels during street driving, and is very rotor friendly.* The Super Street-F compound can be used on all high-performance street applications, and will also perform very well for light track use such as time trials and lapping days events.* Optimal recommend operating temperature range is 75F to 800F.*Product discontinued. Please call for availability.**
CARBOTECH KELATED METALLIC GOLD 914
Similar qualities to our tried-and-true Kelated Metallic Green 913, but with a higher coefficient of friction of 0.50-0.52.* Excellent braking performance, initial bite, modulation and release, and wear characteristics.* Stronger initial bite than Green 913.* Operating temperature range of 100F-850F.
CARBOTECH KELATED METALLIC GREEN 913
A D.O.T.-approved high-performance compound, Carbotech Kelated Metallic (CKM) achieves a very high coefficient of friction (approx. 0.48 to 0.50) by taking advantage of a chemical reaction within the friction mass, which creates a tri-alloy metallic film at the liner/drum interface when subjected to heat and pressure.* Designed to overcome the shortcomings of other liner materials, CKM is very versatile and provides excellent braking performance in a wide variety of applications.* Excellent wear characteristics and a very high resistance to lock-up under hard braking.* Optimal recommended operating temperature range is from ambient to 750F.***
CARBOTECH SILVER STREAK 912
An advance organo-metallic compound specially formulated for rear drum applications in lighter weight race cars (< 2850lb.), as well as disc-brake applications for street-driven vehicles of all types.* High friction coefficient of 0.46 to 0.48, providing excellent braking in the rear without any risk of lock-up.* Very good brake modulation throughout the entire brake pedal travel range, with excellent wear characteristics, providing an outstanding value.* With a price-point significantly below other compounds offering similar performance, Silver Streak is an excellent choice for the budget-minded racer or high-performance driver.*
Old Jul 21, 2005 | 12:04 PM
Gruppe-S's Avatar
Gruppe-S
FERODO
All our pads are R90 compliant and go through extensive research, development and road testing to guarantee safe, controlled and consistent braking.
Ferodo Target top
More material formulations than any other aftermarket parts programme
92% car parc coverage
Regulation 90 approved
Brand name you can trust for safety and quality
All manufactured at Federal Mogul's own ISO quality approved factories
Full complimentary range of brake accessory kits available
Ferodo Premier is the only range of brake pads in the market that matches OE specification materials for every application.
Ferodo Premier top
A full OE specification range of brake pads and shoes
Ferodo is the only manufacturer to offer a range individually tailored to match every vehicle's braking system characteristics precisely
50+ material formulations to comply fully with OE homologation standards
Non-reusable, safety critical accessories included
Full noise reduction specification
Full ABS compatibility (also TCS, EBD, ASC etc)
15,000 mile / 12 month guarantee
Minimal bedding-in period
Excellent fade resistance and water recovery characteristics
Designed for optimum performance and life
Reduced disc wear
DS2500
The DS2500 has a friction level of approximatively 0.50 this remains constant at any speed and at any temperature that the brake system is working at.
the main characteristics of DS2500 are:
-Race developed
-Performs equally well on heavy and light cars
-20% less pad wear than competitive products.
-Minimal bedding-in. Supplied ready to use.
-Disc friendly.
-Consistent friction level with changing temperatures and speeds to give optimal pedal modulation.
-High friction level at low temperature (good cold braking).
-High friction level at very high temperatures.
-35% less compressability than competitive products (racing pedal feel).
-Less noise for increased driving comfort
DS3000
DS3000 is Ferodo's premium racing compound and has set the standard across circuit racing and the World Rally Championship. DS3000 has contributed to countless wins and podium positions in the WRC, BTCC, STW and is now experiencing major success in Indycar and NASCAR applications.
The main characteristics of the DS3000 compound are:
reduced bedding in time (approximately 50% quicker than other materials)
extremely high friction level (0,62 coefficient of friction) at any temperature or speed
higher initial bite
predictability, in all conditions, when braking into the corner because of the flat friction curve
less off brake between the brake pedal and throttle
Please feel free to add to the list if you have more info!
Old Jul 21, 2005 | 07:25 PM
John's Avatar
John
Do you only want what the product listing is, or do you want real experience on the products? If so, then I know that the road racers could provide some input... myself included.
My basic experience with the race compounds in very few words:
Hawks: Never buy them, they destroy rotors and use outdated compounds
Carbotechs: Used XP10s, decent bite, quiet on street, OK feel, rotor friendly
Cobalt: Used VRs, high bite, very loud, solid feel, rotor friendly
From my current track experience, the VRs stop me better...
I'm going to try the PFC01 next for ***** and giggles... that way I can say I've tried it all.
And for the record, this type of thread should be broken down by your driving style and intention. 95% of the drivers here don't take their car to the track, so anything above a good street pad is overkill. IMO, the best streetable pad with an aggressive bite is the Carbotech Panther Plus. I may not like their politics, but I think they produce a great street pad.
Old Jul 21, 2005 | 08:15 PM
daveh's Avatar
daveh
John, please be sure to post your experience with the pfc's. I'm assuming you're going with the tried and true 01 up front and the 97 in the rear?
I'll also add my .02. Porterfield R4 are a great club race pad. Like most pads they don't hold up on the stock rear calipers. R4S is a great street/autox pad but is not a track pad.
Raybestos race pads - using them now. They've almost got too much bite! It's fun watching your passengers head snap forward when you step on them. They wear like iron, I'm on my 5th day of the rears and only have used 1/8th of the pad. Did I say they have lot of bite?!
Tom, you might want to post this in the race related forum. I know you were telling me about the endless pads last weekend. Can you say from personal experience their characteristics? How do they feel in comparison to a popular pad like the PFC01. What are their torque and release traits? How are they on rotors.
Old Jul 23, 2005 | 01:43 PM
ADMAN's Avatar
ADMAN
How you like those 265/35/18:295/35/18 MX Tires? I usually run 40 series in MX on the street. Hadn't thought about going down/wider with Kumho.
I'm trying the Nitto555 right now. Don't know if I like them yet...
Old Jul 24, 2005 | 02:16 AM
racin's Avatar
racin
Have used and sold the PF01's. A great pad, they have been the benchmark of the industry. Pricing is getting excessive, however, and there are a few pads who's performance is about on par with them now. What they have going for them still is that they typically last longer than other comparable pads by about 15-25%. They are extremely rotor friendly with just a little bit of heat in them. And I'd use the 01 compound in the rear too, if the brakes are done right.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
