Will adding Sways to a stock suspension be a worthwhile upgrade?
Old Aug 8, 2005 | 02:51 AM
heezyo2o's Avatar
heezyo2o
Default Will adding Sways to a stock suspension be a worthwhile upgrade?
So will adding just sways improve handling on an otherwise stock Z?
Or should I invest in other suspension mods first such as shocks and springs.
Old Aug 8, 2005 | 05:20 AM
autois4pussies's Avatar
autois4pussies
YES
I have stock susp. and i got hotchkis sways and WOW. So worth it. The car handles way better and takes corners a lot harder without braking traction. Add some good tires and your set.
Old Aug 8, 2005 | 05:36 PM
ssc's Avatar
ssc
yes.
Old Aug 8, 2005 | 06:01 PM
jcpeyton's Avatar
jcpeyton
My FIRST suspension mod was Stillen sways. The difference was noticeable immediately.
Soon thereafter, I added Prothane bushings--another noticeable improvement.
GT Spec front & rear frame braces were next.
WIDE WHEELS and WIDE RUBBER (w/ really aggressive offsets) came next-again another palpable improvement.
Got rid of nismo suspension in favor of Tanabe Sustec Pro S O C--1 1/2" drop.
This car is on rails!!! Don't forget to realign as you go. Prolly not necessary on sway install but anything more advanced will require it.
Old Aug 8, 2005 | 06:17 PM
jcpeyton's Avatar
jcpeyton
An added thought (I know some members will disagree)--I bought Stillen sways because they have the stop collars welded in--saves buying add-on collars.
Also, Prothane bushings (also inexpensive) improve a comparatively inexpensive mod.
My 2c.
hulkout
Apr 28, 2017 09:00 PM
