Stock to Brembo installed owner please help!
Old Aug 23, 2005 | 04:46 PM
imntcrzy's Avatar
imntcrzy
Originally Posted by Jason@Performance
HPS Pads to not have as much initial bite as OEM
yes... I haven't used them, but from what I hear the HPS bite really well provided they are warmed up but cold they are worse than stock.
I use porterfield with goodrich lines and am pretty happy with them
Old Aug 24, 2005 | 03:04 PM
dnguyent's Avatar
dnguyent
I've had some experience w/HPS pads, and I don't think they bite much at all... The Axxis Ultimates bite much harder when cold or hot. The OEM's also bite harder than the HPS pads. For that characteristic alone, I don't really like the HPS's at all, and have abandoned them even though they provide significantly reduced brake dust. Both OEM and Axxis Ultimates dust like crazy.
I'm sure you can get used to the HPS's but you'll have to apply more pedal pressure to get the same amount of friction than the other pads. If you can still set off ABS anytime though, then the HPS is funtionally adequate. It then becomes a matter of preference....brake dust or initial bite.
Old Aug 25, 2005 | 01:17 AM
"DeeZee"'s Avatar
"DeeZee"
When you bled was the ignition in the ON position?? I dont remember why, but I "think" it needs to be? (last time i did mine, i started the car.) Try bleeding just the outer 4 bleed ports (so you dont need to jack it up again.) That should do it. If that does it, then go ahead and do the inner 4 ports as well. pm after your done and let me know how it goes.
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
