View Poll Results: Anti-squeal grease, yes or no?
Voters: 14. You may not vote on this poll
Hawk HPS - Anti-squeak grease or no?
Simple question... I have the pads ready to be installed, and bixby mentioned that I should use some anti-squeal grease. Then again, I *know* others have said not to use it, but I don't know why. Please chime in.
I have hawk HPS. I have squeaks. No amount of bedding in the brakes seem to permanently remove the seqeaks. I thought about trying the anti-squeak grease but was told by my auto-tech not to use the grease because it can reduce your brakes effectiveness. I'll take the squeak and sure brakes over silence and uncertainty.
I still squeak.
I still squeak.
It is recommended to have your rotors resurfaced or turned when changing brake pads. This will stop squeaking.
I went through the whole ordeal with using grease previously when I changed my pads the first time. It didn't help much. The second time, I used grease but there was still squeaking. I went to the dealer and they recommended resurfacing the rotors. As soon as this was done, the squeal went away.
350Z_Al
10-29-2020 07:44 PM
xirtam
10-03-2015 02:06 PM
