Is there a 17" wheel that can go over 14" stoptechs?
Old Nov 18, 2005 | 07:32 AM
  #161
Kolia's Avatar
Kolia
Any news on that ?
Jason, there were talks of a group buy at some point. Will it go forward?
Old Nov 21, 2005 | 02:06 PM
  #162
dnguyent's Avatar
dnguyent
I gave up looking for a 17" wheel that would fit over the 14" Stoptech kit, and got 18x9.5 for all four corners. It wasn't worth my time and effort to test fit rims. Plus, I didn't want to run 10" wide rims up front just to clear my brakes. I think I would have had problems clearing the fender or the vertical control arm.
This thread ended up at a dead end (for me).
Old Nov 21, 2005 | 02:12 PM
  #163
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what wheels did you end up going with?
you can fit 10 up front with no clearnace problems if its the correct offset and at most a 275 tire...
im working with enkei on making a set of wheels exclusive for the 350z...
Old Nov 21, 2005 | 04:13 PM
  #164
03Z33's Avatar
03Z33
If anyone wants my Weds TC-05's they're 17x9.0 et 20 all around and clear the Stoptech 14's... I know it's not a long term solution for everyone, but at least one of you can benefit from these rare wheel
Old Nov 21, 2005 | 04:16 PM
  #165
dnguyent's Avatar
dnguyent
I ended up going with the 18" NT-03's similar to yours. There weren't many wheels to select from, as I really wanted the 9.5" width all around with roughly +30 offsets. I narrowed it down to the Work Emotion CR Kai's, rear Nismo LMGT4's, and the NT-03's. I did not want to run spacers greater than 5mm either. $ was a huge criteria, and the CR Kai and the NT-03 were the only ones left in the selection after I decided all I wanted to spend was around $1300. Less $ would have been great, but they would have been much heavier wheels too.
I even called CCW to have them make a 17" custom fitment, but they could not. They actually recommended I call BBS. I was pretty sure I wasn't going to be able to afford a custom set of BBS since their off the shelf wheels are already pricey.
From what I hear, the NT-03's are strong for a light-weight cast wheel. Some folks had problems with flex in the RPF1 when running R-comps, so I steered clear of ultra light cast wheels, as I suspect they shave off weight in the spokes while retaining strength in the barrel.
Old Jan 1, 2006 | 11:38 PM
  #166
636Racer's Avatar
636Racer
I went with your advice and bought FN01R-C 17x10 +25 up front, along with 17x10 +12 in the back. I will be stretching the tire, going with NT01 245/45 stretching the front, and going a little oversquared with 275/40...the diameters would be affected with the streched tire, but not by much. I would have to stretch it anyways to clear the rear of the tire otherwise I'd be hitting the suspension. Thought about going with RA-1 255/40 and 275/40 but I was unsure about back of tire clearance up front.
Since this is a 14" brake thread, it's good to know that 17" rims will fit 14" stoptechs.
Old Jan 2, 2006 | 09:12 AM
  #167
dnguyent's Avatar
dnguyent
Please post pics when you get the chance!
Old Jan 28, 2006 | 08:38 PM
  #168
636Racer's Avatar
636Racer
back from the dead
FN01R-C 17x10 +25 w/245/40 in front, 17x10 +12 w/275/40 in back. The pic is of the car right off the jacks, I forgot to take one with the suspension at static rest. Looking at the tires, I couldve gone with 255/40 but I found these tires fore really cheap...they're used Goodyear GS CS roadrace tires with lots of life left on them...can't go wrong with these - it was $400 for used *good* tires vs $900+ for new RA-1 tires. Sorry I dont have more pics..I'll take more another time
Old Feb 26, 2006 | 04:58 AM
  #169
Kolia's Avatar
Kolia
Just got my FN01R-C yesterday.
Mmmmmh... flat black, 17x9 and 17x10.
I was surprised, both front and rears are now availlable with an +35 Offset! Much closer to stock (+30/+33), no need for spacers.
We do need tuner splined nuts tought.
Old Feb 26, 2006 | 11:07 AM
  #170
636Racer's Avatar
636Racer
awsome...enjoy them.
Old Feb 26, 2006 | 12:44 PM
  #171
dnguyent's Avatar
dnguyent
Kolia, those should look great! I would have gone with the flat black too...sinister is good.
636Racer, I was wondering whether you'd have any fender clearance issues with such aggressive offsets. My street tires (255 on 9.5 +22 wheels) sometimes brush up against the screws behind the front fenders. I have the hotchkis springs; with stock spring height, I'd probably be fine. That is why I didn't go with the recommended 10" +25 rim up front. Looks great nontheless!
Old Feb 26, 2006 | 04:35 PM
  #172
cwalker's Avatar
cwalker
Does anyone know if the Kosei K1-TS wheels (17x9 +35) will fit over stock Brembo's?
http://www.koseijp.co.jp/engfl/n_p5_k1.htm
I'm thinking of running these with 275 V710's, but just put 1" drop racing springs on and don't know if there will be a clearance problems???
Btw, these wheels only weight 15.6 lbs in the above stated size... how does that compare with the FN01R-C?
Old Feb 26, 2006 | 04:39 PM
  #173
Kolia's Avatar
Kolia
I've weighted mine on my home scale. Note sure of the reliability...
17x9 +35 --> 20.0lb
17x10 +35 --> 21.6lb
Under 900$ for a set, shipped.
Old Feb 27, 2006 | 10:52 AM
  #174
636Racer's Avatar
636Racer
They should clear the brembo but there is another discrepancy you should be worried about. I test fitted 17x9 +35 FN01R-1 and clearance behind the rim was tight. with 275 wide tires, tire buldge might be of some concern because you might end up rubbing the tire against the spindle arm, then you'd have to run a 5mm-10mm spacer and extended studs to clear.
Under hard corning and braking - so far...no issues. The car isnt lowered - still sitting on OEM shock/struts and springs but, I'm using Progressive swaybars. The front rims do stick out a little bit. I havent measured by how much...but I'm guessing between 1" and ½", the rear were a little more. but since the front tires are 245/40...there's a nice stretch to them (it's not as bad as some people may think) and top of the tire width clear the fenders edge. probably moreso when the suspension is under compression when cornering and braking, and the naturally giving off negative camber.
Old Apr 3, 2006 | 02:29 PM
  #175
Kolia's Avatar
Kolia
Tadaaa !
Here are mine:
17x9 +35 wt 255/40R17 RA1 Front
17x10 +35 wt 275/40R17 Rear
Old Apr 3, 2006 | 03:02 PM
  #176
EnthuZ's Avatar
EnthuZ
Looks hot & nasty! Needs a drop though.....The 1st pic looks like you have positive rear camber!
Still waiting for my FN01R-C's
Old Apr 3, 2006 | 03:26 PM
  #177
dnguyent's Avatar
dnguyent
Tadaaa !
Here are mine:
Your car looks like you mean business. I'll try to post up some pics of my enkei's when I get the chance...though my wheels are so shiny and 'pretty', like some track virgin. I need some brake dust and battle scars.
Old Apr 3, 2006 | 03:28 PM
  #178
Nano's Avatar
Nano
looks super badass Kolia! I can't wait to get mine!
How are they clearing the Brembo? Room to spare or tight fit? I think I might need spacers in front...
Old Apr 3, 2006 | 06:42 PM
  #179
Kolia's Avatar
Kolia
Could be some fish-eye effect from the tiny camera I used.
They clear the Brembos very well. I'll get more pictures tomorrow.
I like the matte finish for the No Show All Go look.
Can't wait to try these at MidOhio !
Old Apr 12, 2006 | 04:45 PM
  #180
EnthuZ's Avatar
EnthuZ
My FN01R-C's came in yesterday!!!! A quick weight on my bathroom scale came up with 22 lbs for the 17x10 25mm offset, and 18 lbs for the 17x9 35 offset. A bit pissed as Hop Up lists the 17x10's at 18 lbs.......Oh well, they're lighter than my MB Motorspotr Comps by a bunch and they look nasty in flat black! A big thanks to SPL Parts!
A few local track junkies have Stoptech 14" brakes, and I'll be checking if these wheels fit the big rotors in a few weeks......
