any comment between tein s and rsr spring
how does the car feel for driving.i`m between this two springs because does not lower too much the car having camber problems.so what do you have to say.thanks
The two springs are simular in drop height, but differ in one critical element. The Front S-tech springs are progressive, while all 4 RSR springs are linear. For those unconcerned about performance or how the car behaves at the handling limit's and just wanting a slight drop, this won't matter. Given what the the car is about, I say it does.
Tein S-tech 350Z spring
RSR Down Springs 350Z
RSR 350Z linear springs .6”/.6” drop on 350Z
Spring rates in LBS 345/417
Stiffer then oem 03/04 without revised suspension by F+10% R+22%
Stiffer then oem 04.5+ (revised suspension) by F+10% R-3%
Tein S-tech 350z (fronts progressive, rears linear) .7”/.6” drop on 350Z
Spring rates in lbs 386/402
Stiffer then oem 03/04 without revised suspension by F+23%* R+16%
Stiffer then oem 04.5+ with revised suspension by F23%* R-6%
*(final rates only, softer initial front progressive rate unknown)
If your rear shocks have a pale yellow metalic colored label with a bar code on them, yes. I would not ask the oem rear shocks to handle more then 427lbs anyhow, not unless upgrading the shocks was also part of the plan.
