Is there any suspension upgrades I can do ????
Old Sep 20, 2005 | 03:46 AM
CoNismoZ's Avatar
CoNismoZ
Default Is there any suspension upgrades I can do ????
The question is is there any suspension upgrades I can do on my car that dont mess with AVC on the Touring model??? Alot of the sites say no sway bars no coil over system no springs cause is will cuase the AVC to mess up and not work properly ?? Is this true what can I do??? If anything.
Old Sep 20, 2005 | 06:04 AM
briang35's Avatar
briang35
what have you heard about coilovers affecting it? my vdc system does some pretty strange stuff and i can't figure out if its just a sensor or what. driving around normal in the dry is about as i'd expect it if you corner too quickly or shift into 2nd too fast but i can spin the tires at least a few revolutions in the wet from a stand still without even seeing the slip or vdc light. also it seems to trigger the slip light and reduce power when i drive up a steep driveway at an angle.. and finally after turning vdc off i can do doughnuts and other fun things but it feels like my front brakes pulse the first time i come to a stop immediately afterwards
Old Sep 20, 2005 | 10:38 AM
hndumafia's Avatar
hndumafia
no suspension mod should affect the way the VDC works on the Z. On my track model, which also has VDC, i have sway bars and springs, and I have no problems at all. A lot of companies, including Nismo, say their equipment isn't to be used with VDC only because the haven't tested on cars that are VDC equipped.
Old Sep 20, 2005 | 11:05 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
ive got new sways, springs, struts (see sig) and my vdc is just fine.
but as for coilovers, idk.
Old Sep 20, 2005 | 11:42 AM
plumpzz's Avatar
plumpzz
Should've gotten enthusiast edition :-D
Old Sep 21, 2005 | 02:17 AM
CoNismoZ's Avatar
CoNismoZ
Thanks everyone for the answers guess ill be getting suspension goodies after all thanks
