Would you lower this Z?!?!?!
Old Oct 16, 2005 | 01:05 PM
lexus33's Avatar
lexus33
Default Would you lower this Z?!?!?!
Guys I am really struggling about if I should lower and also use spacers on my wheels to complete the look. I don't know if it is worth it. Some Z's I can see it is obvious but half the people I ask are 50/50. I will try to get another pic but this is all I have right now on this PC.
The offset of my wheels is +35 but for some reason they don't look terrible.
Thanks
Old Oct 16, 2005 | 01:06 PM
Sensation350Z's Avatar
Sensation350Z
Don`t go based on others opinions. It`s your car, your money, etc.
Old Oct 16, 2005 | 03:10 PM
rx7/350z's Avatar
rx7/350z
i lowered my car (tein basic) with 19x8 all around 35 offsets the front will look ok but the back will look too far in. get spacers, i used h&r 25mm for the back and it looked great. I just got 20x10 for the rear and i have the spacers for sale now .................pm me if intrested.
Old Oct 16, 2005 | 03:17 PM
usmanasif's Avatar
usmanasif
What pics?
Old Oct 16, 2005 | 06:10 PM
lexus33's Avatar
lexus33
IDIOT!!! Would help if I posted the darn pic sorry...
rx7/350z - sent u a PM
Old Oct 17, 2005 | 08:13 AM
Spooky's Avatar
Spooky
From the pic it looks like you have very little space between the tire and fender. I don't think you need to lower it.
However, if the space bothers you now, it will bother you everytime you look at the car until you lower it. That's how I get about details like that.
Old Oct 19, 2005 | 12:58 PM
xtrememan315's Avatar
xtrememan315
I say don't lower it! Look pretty good from that pic!
Old Oct 19, 2005 | 01:59 PM
cessna's Avatar
cessna
I agree....
Old Oct 19, 2005 | 02:03 PM
2004z's Avatar
2004z
Sleeps in 350Z
yeah, i would lower it
Old Oct 19, 2005 | 02:09 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
If you're considering dropping your car, get some tein s-techs. It lowers it just a TAD bit which IMO make a big difference in looks with aftermarket rims. I wouldn't drop it more than the .6 inches that the s-techs offer though. Slammed cars just aren't practical where I live. I would scrape the bottom 5x as much as I do already.
Old Oct 19, 2005 | 02:10 PM
mgl's Avatar
mgl
i would lower it.
i was struggling with the same dilemma about lowering my z.
i finally did lower it with tein basics and i think it looks a lot better lowered.
Old Oct 19, 2005 | 02:25 PM
zland's Avatar
zland
Sport Z Magazine
I lowered my Z 1" all 4 corners and here are the pros and cons:
Pros:
1. I love the way it looks.
2. I think it handles better than stock. The negative camber is great for cornering.
3. Ride is smoother believe it or not than stock.
Cons:
1. Speed bumps. Scraping is a way of life now and even exiting steep driveways is bad news. You learn to drive accross bumps etc on angles and slow down to a crawl. This will force you to change the way you drive on a daily basis.
2. If you go beyond .75" drop, you will be out of spec on camber (regardless if you get a 4 wheel alignment or not, which i did BTW) thus wear the inside of your tires. I got toyo TS1's on mine which are suppose to be a good wearing performance tire. After 13K miles, mine are almost down to nothing thus maybe 2k more on them. At over $1000 a set the question arises... How bad do you want to drop your Z?
Old Oct 19, 2005 | 07:21 PM
Zivman's Avatar
Zivman
100% WITHOUT A DOUBT NEEDS TO BE LOWERED
Just get Hotchkis springs and forget about it.
Old Oct 21, 2005 | 01:51 PM
lexus33's Avatar
lexus33
So the Hotchkis springs don't raise any of the problems from the above mentioned? Will I have camber issues, tire wear issues? I was told the Eibach kit is the ONLY kit you can use that will turn the car back to stock camber after a 4 wheel alignment?
Am I wrong?
Old Oct 21, 2005 | 02:01 PM
lexus33's Avatar
lexus33
What if I just got some 15mm wheels spacers, maybe that will give a nice aggressive look but without the headache of all the lowering, and camber issues? The wheels do sit in a bit with the 35 offset on the HP's 19's? Thoughts...
Old Oct 21, 2005 | 02:49 PM
Zivman's Avatar
Zivman
like I said, get the hotchkis. You will be able to align within spec. the eibachs will have a harder time than hotchkis will in terms of getting to spec.
Lower it and then see if you think spacers are needed
Old Oct 21, 2005 | 06:39 PM
1nate7's Avatar
1nate7
Get 15mm spacers AND lower it. If you just add spacers, the wheel gap will be more noticable because the wheel will be flush with the fender. If you just lower it, the extra - camber will make it look like the wheel is tucked in more. Hotchkis, RS*R, and Tein S-Techs are all about a 3/4" drop that shouldn't throw your alignment out too bad.
Old Oct 21, 2005 | 08:15 PM
lexus33's Avatar
lexus33
Really so the Hotchkis and the tein s techs only need a wheel alignment after and I will be good to go...hmmmm well that is good to hear. I heard I had to go trough the whole camber adjustments and all that jazz with either of those kits...
I will look into it.
Any good sites for the Hotchkis, they are harder to find the Eibach's
Old Oct 22, 2005 | 07:19 AM
1nate7's Avatar
1nate7
It depends, but the lower you go the more negative camber you will have. That is why I recommended the springs I did, because they will give you the best chance at being within stock alignment specs while closing up some of the gap. I know Intense carries the Hotchkis springs, and you might want to consider getting the sway bars as well. You can get the whole package for around $400 shipped.
Old Oct 22, 2005 | 11:40 AM
lexus33's Avatar
lexus33
1nate7, is this the kit you were talking about? Will this also lower the car, it doesn't say in the decription. Also is it about an inch? More / Less.
After this kit just a wheel alignment and I am good to go?
Thanks
