spring... tein?
Old Oct 31, 2005 | 09:46 PM
lemonjihwan's Avatar
lemonjihwan
Default spring... tein?
is 'tein's the way to go? when you wanna lower your car with out spending too much money.
by the way, is there any spring called s.pillar???
Old Nov 1, 2005 | 10:21 AM
Zivman's Avatar
Zivman
You want hotchkis. Designed to work with oem absorbers, provide a more balanced drop than the teins, and you will be able to pull within oem specs.
By "s.pillar" I would guess you are refering to Espelir.
Old Nov 1, 2005 | 11:07 AM
lemonjihwan
espelir!!! omg f**king stupid me...+.+
hows espelir springs with stock shocks???
how much does hotchkis cost about?
Old Nov 1, 2005 | 12:53 PM
Zivman's Avatar
Zivman
don't even look at other springs. The hotchkis are the answer (unless you want to spend some big $ and get full coilovers).
CALL http://www.gscmotorsports.com/ The springs are about 150 shipped and the full TVS package (springs and front and rear sways) is about 425-440 shipped
Old Nov 1, 2005 | 01:06 PM
lemonjihwan
do i need a front and rear sways to make perfect drop?
or am i koo with just the spring??
by the way, thanks for the information zivman. helping me out alot!
Old Nov 1, 2005 | 01:13 PM
Zivman's Avatar
Zivman
All you need is the springs for the drop. The sways will tighten things up and improve handling. You choice if you want to get them as they are not needed for just lowering the car
Old Nov 1, 2005 | 01:21 PM
ActionJackson's Avatar
ActionJackson
I would recommend getting the sways too, many people on the forums here have said that sways are the single best suspension mod for our car, and make the most difference in handling.
Old Nov 1, 2005 | 01:22 PM
robbycolli's Avatar
robbycolli
How much of a drop will they give? I had all these same questions. Thanks for the help.
Rob
Old Nov 1, 2005 | 01:28 PM
jondimellow's Avatar
jondimellow
i am thinking of getting lowering springs for my car too.... after you break in the springs, do you need to align your wheels?
Old Nov 1, 2005 | 01:41 PM
Zivman's Avatar
Zivman
Springs don't break in. They also don't settle. Once you have stressed your suspension after your spring are installed, you do need an alignment.
The hotchkis drop 9/16" front and 3/4" rear
Old Nov 1, 2005 | 01:42 PM
lemonjihwan
whu chu mean break in spring??? damn.. im know **** about suspension-.- so guys, all i need to get is that TVS pakage and give it to shop to install?
Old Nov 1, 2005 | 01:44 PM
Zivman's Avatar
Zivman
Get the TVS and get them installed and be done - other than an alignment. Great improvement in looks and handling. Make sure to call GSC vs ordering online. They will give you a better deal.
Old Nov 1, 2005 | 01:47 PM
lemonjihwan
zivman, who should i ask for.. when i call? do i tell him that im from my350z.com?
Old Nov 1, 2005 | 03:06 PM
Zivman's Avatar
Zivman
Talk to Greg or Stephen. Tell them you are from the Z forums
Old Nov 1, 2005 | 04:23 PM
lemonjihwan
thanks zivman for everything!
Old Nov 1, 2005 | 05:21 PM
palepony's Avatar
palepony
lemon
with respect to zivman's comments "You want hotchkis" ; "don't even look at other springs"
i would agree with zivman, but would ask you first if this is what describes you and your goals
1. own a 2004 (as per your avatar) VS the revised 2004.5 make year.
it makes sense that the hotchkis were designed with OEM in mind. however, the OEM suspension is different depending on your make year.
2. want handling similiar to the 2003-2004 OEM spring rates
3. want a moderate drop (as zivman listed)
4. don't want to buy alignment hardware
5. don't want to buy new shocks
if that's your profile, you've got your springs. hotchkis definitely also fits your comment about "not spending much money"; the price is right.
however, if you answered no to any of those, you have other options.
pp
Old Nov 1, 2005 | 06:40 PM
lemonjihwan
palepony, haha thank you very much!
let me see...
1. yes, i do own a early 2004 model.
2. handling, hmm as long as it doesnt get worse. im fine. because im lowering my car mainly for the looks. of course itll be nice if i get better handling!
3. this part is the only part that im worring about. how much do they lower your car?
4. yes, i definitely dont wanna buy hardware.
5. yeah, dont wanna buy new shocks.
Hotchkis is the way to go~?
Old Nov 1, 2005 | 06:42 PM
lemonjihwan
oh also, im debating if i should get the spring or the TVS kit.
Old Nov 1, 2005 | 07:01 PM
palepony's Avatar
palepony
lemon
with the responses you gave, yes, hotchkis would be a good choice.
the reasons being:
1. they are close to your stock spring rates, the slightly lower spring rates in the rear will be better handled by your OEM shocks/dampers (a proposed weak point of the early OEM suspensions)
2. the amount of lowering is about the most you can go without needing aftermarket alignment hardware. that being said, you could run lower with other springs, by accepting a more aggressive camber (there is a tanabe spring thread discussing this). but if you want close to OEM alignment specs, hotchkis are your springs
zivman listed how much the car will be lowered. there are pics on hotchkis website and on this forum.
as for the TVS. if you have the budget, absolutely get the sways, or some other brand. they will give you a degree of adjustment to fine tune your handling characteristics. if you don't have the budget now, you can always add them later.
hope that helps
pp
Old Nov 1, 2005 | 07:15 PM
lemonjihwan
drop of 9/16" front and 3/4" rear seems kinda...
am i even gonna see the difference? with that amount of a drop?
p.s. my car is sittin on 19x8.5 with 245/35 toyo's on front and 19x9.5 with 275/35 on Rear. the offset is both 22. thought maybe this would help.
