Cusco/SPC Setup
Old May 4, 2006 | 04:39 PM
changsw's Avatar
changsw
So let me ask you, do you have any rubbing issues? What is your camber for both front and back?
Old May 6, 2006 | 11:37 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Originally Posted by Z1 Performance
Not true - I am lowered 2 inches and can still get both sides down to 1.2
It's got ALOT to do with your wheels and tires as well - the lower your offset and the wider your front tires, the more askew your camber will be
Second, the car LOVES front camber, and it has nothing but upsides - with -1.5 up front, and a bit more out back, my car is literally the most neutral driving car I've owned to date
Great feedback. Negative camber can be excellent for handling - which is why I have been puzzled with people wanting to pull it out.
What exact negative camber are you running .. front and back ? Is this the best for handling, in your opinion ?
Thanks !!
Old May 7, 2006 | 09:57 AM
changsw's Avatar
changsw
Still waiting on something from SPC for front camber.
Old May 8, 2006 | 10:43 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I run -2 degrees out back, and usually -1.5 ish up front. Is it the best? Hard to say, as it varies by so many factors. Personally, I found it to be an awesome combo of turn in response, stability when powering down mid turn, and it suits my driving style well. No tire wear issues at all, and I've now got more than 10k miles on my S03's (they were new around this time a year ago).
Old May 8, 2006 | 01:57 PM
fairladyZ in Japan
Thank you very much for your feedback !! When I get a chance, I am going to have an alignment dialing in your camber. Want to see if this improves the turn in response of the PS2's.
Old May 8, 2006 | 02:02 PM
changsw's Avatar
changsw
Wow really, no tire wear issues? I guess the Z really does like camber. On my tires, without camber kits mind you, I notice that the inner tread is dirtier that the outer tread, obviously because of negative camber. Since I don't race my car or anything like that, I'd like to keep my tires for as long as possible. I think -1.2 up front and -1.5 or so out back is good. What do you recommend for people like me? Thanks.
changsw's Avatar
changsw
Oh and I hope -1.2 (f) and -1.5 (r) won't causing rubbing issues, because currently I have none.
Old May 9, 2006 | 07:31 AM
Z1 Performance
Former Sponsor
I cannot tell you if it will rub or not - too many variables at play
the toe is most likely causing your tire wear issues, not camber. That is, unless you drive ALOT of miles of pure, straight highway
Old May 9, 2006 | 08:08 AM
changsw's Avatar
changsw
Well, I have approximately -1.7 up front and -2.3 in the back. I forget the exact numbers for toe but it is within spec. I want to get my camber back into spec at the very minimum. Thanks for the reply.
Old May 9, 2006 | 08:40 AM
jimster716's Avatar
jimster716
Does anybody have any specs on how negative I can get it? I don't want the camber arms to get back into spec - my alignment guy needs them to give me an aggressive autocross setup. Thx.
Old May 9, 2006 | 07:12 PM
Z1 Performance
Former Sponsor
how negative what will get you?
Old May 9, 2006 | 09:54 PM
jimster716's Avatar
jimster716
Negative camber with the cusco front a-arms. Thx.
Old May 10, 2006 | 06:46 AM
Z1 Performance
Former Sponsor
I've never measured the exact amount of negative I can get - I am at 1.5 now, and I'd estimate I could get another -2 degrees out of them
Old May 10, 2006 | 09:03 AM
jimster716's Avatar
jimster716
Cool, thanks!
Old May 11, 2006 | 05:08 AM
fairladyZ in Japan
I know a lot - but I am no expert by a long shot ...
Can anyone give me their input ..
1/ Without using Cusco / other adjustable arms -- can the camber be set to a desired negative of around 1.5 for the front and 2.0 for the rear ?
2/ I know that the adjustable arms are usually used to bring larger wheel settings into spec by having the ability for more positive settings.
Therefore ...
Cusco has been used for negative settings ... what are the advantages of Cusco -- better negative settings ?
Old May 11, 2006 | 07:04 AM
Z1 Performance
Former Sponsor
1. no
2. search Been covered to death! Seriously though, the Cusco arms offer both positive and negative correction - like any other a arm on the market, they offer more negative than positive, as you are limited by the 1. design of the arm and 2. the fender well. The more radical your wheel/tire combo and/or the more radical your drop, the more adjustment you need. It is too time consuming to list every possible combination, but on my own car I have 18x8.5 +20 wheels, with Potenza S03's in 245/40/18, and can easily bring my front to stock specs if needed. By choice, I run slightly more aggressive front camber than stock, as it offers tons of benefits and to date, zero negatives
350Z_Al
Oct 29, 2020 07:44 PM
