Budget lowering?
Old May 8, 2006 | 02:35 AM
KDW2002's Avatar
KDW2002
Default Budget lowering?
Well, my budget is about to max out, but I still need lowering for my Z.
I found some nice rims, but I really need lowering!
Is their a cheaper way than going with a fully suspension?
Has anyone done just the springs, or would that be a shame on the Z?
Please let me know what you think.
Old May 8, 2006 | 03:05 AM
abstrakt's Avatar
abstrakt
People are running lowering springs in combination w/the stock shocks. Hotchkis would be a nice alternative and also not break the bank as well as Tein S-Tech's or the H-Tech's. It all depends on how low you want to go.
Old May 8, 2006 | 04:04 AM
Kolia's Avatar
Kolia
Handling will not be so good and the OEM dampers will wear faster.
But yeah, you can run lowered springs only.
Just stay away from dilatation joints on the highway...
Considering the cost of the springs+installation+alignement involved, you might want to wait a bit and get the whole package done at one time.
If you do the install yourself, its not that bad, but otherwise, spending for the re-installing of the suspension plus a new alignement is not cost effective.
Old May 8, 2006 | 07:12 AM
MIAPLAYA's Avatar
MIAPLAYA
I have two sets of springs for sale. B&Gs and Hotchkis...PM me if you are interested...
Old May 8, 2006 | 04:08 PM
Gsedan35's Avatar
Gsedan35
Z33 lowering springs that have enough spring rate increase as to impact shock life are very rare. Most all only offer up a mild increase in spring rate vs oem of only 5 to 14%.
It doesn't hurt to find out in posts like this if the owner has revised or unrevised shocks. The original shocks on these car's don't take as well to lowering springs as the revised shocks will, though Hotchkis springs were specifically designed to work with them.
Heres one lowering spring that comes to mind that would likely based on peak spring rates, impact shock life if at all. (excluding the Nismo T2 springs on purpose)
Espelir active GT 350Z part#ESG055 .4"/.4" drop progressive springs
Spring rates* 386/515 (softer initial rates unknown, peak rate ONLY shown)
Old May 10, 2006 | 06:06 PM
KDW2002's Avatar
KDW2002
I squeezed my budget a little more and decided to go with a fully adjustable suspension..
The Ksport which is adjustable in height, hardness and camber.. I got a good price on it from the my local Ksport dealer, thats why I went with this particular setup.
Has anyone tried it or have any comments on it?
Old May 10, 2006 | 09:56 PM
aleok's Avatar
aleok
let us know how they turn out and post pics!
Old May 11, 2006 | 02:16 AM
S12 driver's Avatar
S12 driver
You can probably get some used springs w/new Tokico shocks and save some money over getting full coilover.
Old May 11, 2006 | 07:57 AM
teh215's Avatar
teh215
How much drop do these offer?
Old May 11, 2006 | 08:55 AM
MIAPLAYA's Avatar
MIAPLAYA
The Hotchkis are less then an inch while the B&Gs are like 1.5" front and rear..
Old May 11, 2006 | 01:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
And I *still* scrape the cats on certain driveways on hotchkis. You guys lowering more than 1" are nuts
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
