camber arms and toe arms and toe bolts?
Old 11-28-2005, 03:47 PM
solarscar
solarscar's Avatar
Default camber arms and toe arms and toe bolts?
I bought some adjustable camber arms like these for my car and installed them...
but recently found out i need to adjust the toe, so i looked on ebay and found that you can buy toe bolts to do this and they are just a couple bolts... BUT, then i found out that we have also have toe ARMS on our car. Here is an example of the toe AND camber arms we have..
My question is can i get away with just buying these (see below pic) to fix the toe problem or do i need actual toe arms?? It is really confusing the crap out of me and i need some help cause i can't drive my car the way it is, my tires are going quick!!! I have to drive my OLD nissan truck. lol.
here's the link to the auction:
ebay toe bolt auction
Please let me know what i need to buy to remedy the problem. Links would be nice or pictures. Thanks.
Adam
Old 11-28-2005, 04:38 PM
Road Warrior
Road Warrior's Avatar
i bought the sbc camber bolts...and thats all they require for adjusting toe so its not necessary to buy both
Old 11-28-2005, 06:28 PM
solarscar
solarscar's Avatar
Okay, the toe bolts go through the toe arms right? I just don't understand i guess how the bolts will adjust the toe since the arm can't be lengthened/shortened. Please explain.
Old 11-28-2005, 08:23 PM
solarscar
solarscar's Avatar
?? aaaanyone??
Old 11-29-2005, 04:52 AM
GaryM05
GaryM05's Avatar
Originally Posted by solarscar
?? aaaanyone??
Sorry I don't have much time to reply, but a quick search will answer this.
But the short version is: get camber arms, and toe bolts. Do not get what you're calling 'toe arms.'
Old 11-29-2005, 06:25 AM
rocketdog
rocketdog's Avatar
the toe bolt is a cam in an oblonged hole. when you rotate the length changes. you'l need camber adjustable arms, SPC toe bolts and front upper adjustable a-arms.
Old 11-29-2005, 12:55 PM
solarscar
solarscar's Avatar
why do my posted keep getting moved???
Old 11-29-2005, 01:17 PM
MIAPLAYA
MIAPLAYA's Avatar
The toe bolts are all you need. Protocav did a write up on how to install them:
http://members.***.net/chadisrad/SPC.pdf
Old 11-29-2005, 01:37 PM
solarscar
solarscar's Avatar
Now thats a good response!! Thank you very much for the link, excellent!
Old 11-29-2005, 03:01 PM
MIAPLAYA
MIAPLAYA's Avatar
No worries...
Old 11-29-2005, 03:54 PM
solarscar
solarscar's Avatar
After i go to the alignment shop with my new adjustable camber arms and the new SPC toe bolts installed, should i tell them about these two things, i mean, we have mainly rednecks in my town that work on fords and stuff all day long. haha. I really don't know how often they have seen an adjustable camber arm or a toe bolt that some elongated the hole before installing. Any experience with this?
Thanks
Old 11-29-2005, 04:26 PM
MIAPLAYA
MIAPLAYA's Avatar
Thanks
I'm sure they'll know what to do. Have them do the following.
Set rear toe to 0 after setting toe (done by turning the bolt) loosen the camber arm and adjust to -1.5. Have them recheck the toe as it may move. You basically play this game of back and forth till you get -1.5 camber in the back and 0 toe.
Old 02-15-2006, 10:50 AM
NISMOFO
NISMOFO's Avatar
I could see how putting the toe at 0 would be good for tire wear, but not for basic handling at all. I'm just talking about basic handling characteristics on our cars. As far as I know, when you have an independent rear suspension some toe-in is required on all cars.
I agree 100% on the -1.5 rear camber though.
Can anyone else verify that trimming only the inside of the holes for the toe-bolts is required???
08-06-2021 06:19 AM
04-22-2021 09:42 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
Quick Reply: camber arms and toe arms and toe bolts?
