Lowering Roadster Recommendations
Old Dec 24, 2005 | 06:47 AM
adidaskobe's Avatar
adidaskobe
Default Lowering Roadster Recommendations
Anybody have recommendations for a slight drop in a roadster?
Don't track so just looking for a slight drop while maintaining comfortable ride.
Old Dec 24, 2005 | 07:01 AM
Zivman's Avatar
Zivman
hotchkis TVS
Old Dec 24, 2005 | 07:33 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Eibach Pro Spring and Koni Shock.
Old Dec 25, 2005 | 11:49 AM
Gsedan35's Avatar
Gsedan35
Is your idea of a "slight" drop as much as 1"?
prokit's will drop you 1"
The RSR springs will drop you .6" and use linear spring rates that are inline with your oem setup which features the revised Z suspension's specs since all roadsteers have the revised suspension.
Old Dec 26, 2005 | 12:32 AM
WA2GOOD's Avatar
WA2GOOD
Eibach Pro-kit springs and Tokico D-spec adjustable shock. Great looks, performance, and price. (even better with some sway bars)
Old Dec 26, 2005 | 02:31 AM
350ztoronto's Avatar
350ztoronto
how much will that setup run?
Old Dec 26, 2005 | 07:59 AM
visionboy's Avatar
visionboy
for just a slight drop, go with the hotchkis. I got the Eibach pro kit and i feel it's too low and a little bouncy...everyone says my car is slammmed!
Old Dec 26, 2005 | 08:06 AM
roncfpz's Avatar
roncfpz
Originally Posted by Zivman
hotchkis TVS
+1 on this kit for a "slight" drop.
Old Dec 26, 2005 | 08:36 AM
Gsedan35's Avatar
Gsedan35
The only thing I can bring up about the Hotchkis springs and this is for roadsteer owner's and coupe owners of 04.5+ cars would be that your picking a setup that uses a lot softer rear springs then oem. Won't say that's the end of the world at all, but the RSR springs come to mind vs the Hotchkis springs for this reason. The Hotchkis springs were specifically developed for 03/04 cars with the softer rear spring rates used to rain in the rear shocks tendency to allow the car to bounce. Thats not a issue on the car's were dealing with here.
Oem roadsteer and 04.5" Z spring rates
314/427
RSR 350Z linear springs .6”/.6” drop on 350Z
Spring rates in LBS 345/417
Stiffer then oem as defined above by F+10% R-2%
Hotchkis 350Z Linear springs .6”/.8” drop on 350Z
Spring rates in lbs 340/330
Stiffer or softer then oem as defined above by F+8% R-20%
Old Dec 26, 2005 | 01:48 PM
WA2GOOD's Avatar
WA2GOOD
Approximately $700 + $300ish for the sways. This IMO, is a pretty mild drop, to be even more performance minded and lower, use Eibach Sportline springs.
Old Dec 26, 2005 | 04:44 PM
Gsedan35's Avatar
Gsedan35
Keep in mind that he's running g35 coupe eibachs, totally different specs then 350Z eibachs.
Old Dec 27, 2005 | 12:53 AM
350ztoronto
frig, i have an 05 GT ZR will the tein basic be ok?
not tracking just want something comfy and a nice drop with 19's
Old Dec 27, 2005 | 07:22 AM
Gsedan35's Avatar
Gsedan35
Basics will definately be firmer, but they still get very good review's by their owner's. It's not a track oriented coilover, but it may be firmer then your hoping for. Here are two good review's for you to read.
https://my350z.com/forum/showthr...6656#post926656
https://my350z.com/forum/showthr...&threadid=94591
post number 9 & 10
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
