with dot 5 companies recomend to change brake sistem because the quimicals used on dot5 products destroy the rubber used on street cars. be carefull driving your Z hard bacause you dont know when is going to fail.
That is Dot 5, but the discussion is Dot 5.1, which is different than Dot 5. AFAIK Dot 5.1 it should be safe for use on the Z. I personally am using ATE super blue.
