Brakes - pads & rotors - advice needed
Old Jan 5, 2006 | 09:19 PM
Mike Wazowski's Avatar
Mike Wazowski
EBC Red Stuff Pads are not really track pads they are high horse power street pads. Yellow stuff pads are for the track. Green stuff pads are for lower horse power and everyday family vehicles.
Old Jan 6, 2006 | 03:57 AM
Vamos_Rafael's Avatar
Vamos_Rafael
yep...
reds are street pads with track compounds aka better stopping power and stronger lasting
yellows need to get warmed up b4 it works
and greens... are for beaters
Old Jan 6, 2006 | 06:50 AM
buho62's Avatar
buho62
Originally Posted by jvanquish
Check the rears... good brake balance is crucial for good stopping power!
Doesn't the Electronic Brake Force Distribution takes care of that? or it doesnt really balances the brakes??
I hope it does. Thats one of the things I thought it was cool about the Z
Old Jan 6, 2006 | 07:01 AM
Vamos_Rafael
your rear then have to work harder...
Old Jan 6, 2006 | 07:04 AM
PoWeRtRiP's Avatar
PoWeRtRiP
those rotors are gonna be $$$ i strongly urge u to get a second opinion, and if u do replace the rotors do not go with oem. performance nissan should have a nice selection of aftermarket rotors on their website, check it out.
most likely new pads and rotors will cost u over 500. pads will be about 100, rotors i have no idea but can easily see them being over 100 each. best of luck.
Old Jan 6, 2006 | 07:06 AM
Vamos_Rafael
Check tirerack... they usually have brake set up for cars and they ship pretty fast
Old Jan 6, 2006 | 08:14 AM
Z_Driver's Avatar
Z_Driver
Master
EBC are great pads
I'll second that !!!!
Old Jan 6, 2006 | 08:21 AM
Vamos_Rafael
Originally Posted by Ztalker
if you don't go to track and the Z is your daily driver, i would think twice before i replace the stock pads with high performance racing pads cuz they are meant to operate at higher temperatures at the track and you wouldn't appreciate the increased stopping distance on the streets.....believe me, been there done that....
Stock pads are #terrible
You need to NOT buy them again
Old Jan 6, 2006 | 02:04 PM
showstoppertk's Avatar
showstoppertk
+1 on the stoptech stage 2 kit. I got the same story when I had my brakes done at 22k miles, but I had only bought the hawk pads b/c I didn't think my rotors where going to need to be replaced so I had to just buy stock replacements. the stoptech kit will give you new hawk hps pads, slotted rotors, steel lines and motul fluids I believe. talk to jason (he's a member on here) from performance nissan, he'll hook you up.
Old Jan 6, 2006 | 02:05 PM
showstoppertk
Old Jan 6, 2006 | 02:08 PM
Vamos_Rafael
i'd rather have hawk red pads or project mu's rather than hawks
Old Jan 6, 2006 | 02:19 PM
heezyo2o's Avatar
heezyo2o
A BBK kit such as the stoptechs would be overkill if you don't go to the track. There are better than stock brake pads out there, but since you were surprised with the rotor with stock pads, I'd be weary of an aggressive pad which should increase rotor wear.
Old Jan 6, 2006 | 02:22 PM
Vamos_Rafael
Brakes save lives...
Get the most powerful brake so you can both take more risks and avoid more risks
I should be a stoptech brake salesman
Old Jan 6, 2006 | 02:26 PM
heezyo2o's Avatar
heezyo2o
For street use, I just know of the hps and HP+, what the hell are the reds.
Old Jan 6, 2006 | 02:28 PM
heezyo2o's Avatar
heezyo2o
For street use, it doesn't make a difference. If you're in it for looks, that's one thing, but for actual stopping distances, the difference is minimal.
Old Jan 6, 2006 | 02:30 PM
heezyo2o's Avatar
heezyo2o
Have you seen this test http://www.zeckhausen.com/Testing_Brakes.htm
Those "terrible" stock pads and rotors do quite well. Again, for daily driving and the street, a bbk kit is a waste.
Vamos_Rafael
EBC redstuff
(more performance oriented than greenstuff but still streetable)
Stopping power with the stoptech bbk is noticable and a couple feet could mean the ditch or a "phew"
Old Jan 6, 2006 | 02:37 PM
  #38
heezyo2o's Avatar
heezyo2o
EBC redstuff
Check your post, you mentioned "hawk reds."
There may be better brake feel with a bbk, but the argument about stopping power is mute.
I really don't know of an instance where one would face brake fade on the street. I've done numerous canyons runs on the non-brembo pads and rotors as well as the OEM brembos and even then I did not experience fade.
Old Jan 6, 2006 | 02:41 PM
  #39
Vamos_Rafael
yes BUT say you get 3 feet less from using BBK compared with regular brake ..
then say you got into an accident and if you had BBK you would of avoided it
now you lost 5000 dollars on a Z instead of spent 2000 dollars on the brake kit and avoided the accident over all
Old Jan 6, 2006 | 02:54 PM
  #40
heezyo2o's Avatar
heezyo2o
That argument is flawed because if you have to apply maximum braking/emergency braking from 80 or 100mph, then you're in trouble to begin with. Even then, ABS will kick in which should allow you to swerve to avoid danger. If such a situation were to arise, reaction time would be much more important than what type of brakes you have.
If you were to try similar braking techniques in a turn, it would be game over even with VDC, BBK or not.
