Shocks and Springs
Old Jan 8, 2006 | 06:37 AM
zredline's Avatar
zredline
Default Shocks and Springs
I am considering getting new shocks and springs for my Z and wanted to make switching the fronts simpler by putting together the new shock and spring and not use parts off the original fronts. I saw this on the performance Nissan web site :
http://performancenissanparts.com/ca...oducts_id=3532
Is this all I would need to put the fronts together prior to installing?
I am considering the RS-R Ti 2000 with Konis or Tokico.
Thanks.
Old Jan 8, 2006 | 08:58 PM
ecorona6's Avatar
ecorona6
The kit is useful for a coilover (Tein Basic) than does not include the hats (performance nissan kit). By purchasing the kit you avoid taking your original shock/spring to a shop and paying the remove the EOM hats. Since the springs on a coilvers can be brought down completly without compresson any body can mount the kit to their coilvers.
In your case you will still have to take the purchased kit to a shop in order to compress the spring enough to allow the hat installation. You will have to spend another $20-80 (depending on shop) to place both hats on your new spring and shock combo......
Skip the kit and take off OEM Shocks (2 front) and pay $20-80 to replace hats to your new combo.
Good Luck.
Old Jan 8, 2006 | 09:03 PM
Mike Wazowski's Avatar
Mike Wazowski
Those Tokico's are a great choice.
Old Jan 8, 2006 | 09:04 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Install if you are handy with tools is simple with proper help after you get the springs on....^^
Nihsnek
Feb 9, 2016 12:57 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
