StopTech's 6piston Beauuuuttyyyy... ;)
Old Mar 10, 2006 | 03:47 PM
  #41
BremboGuy's Avatar
BremboGuy
Hey...that's a Brembo disc on Lou Gilloti’s World Challenge Corvette.
I'd love to hear the reasons why he's running our 355x32mm Type 3 Race Disc rather than Stoptech's "patented AeroRotor® featuring 10-30% more airflow".
That's awesome.
[QUOTE=DZeckhausen]Here's a shot I took while wandering the pits at Lime Rock last year during the SPEED World Challenge races:
QUOTE]
Old Mar 10, 2006 | 03:51 PM
  #42
DZeckhausen's Avatar
DZeckhausen
That's awesome.
If you know Lou, you know he's very, shall we say, frugal. That was a leftover set of rotors that he ran a very long time ago. Now he's running the Aerorotors.
You want to see another example of frugal? Check out those universal wheel spacers! Aaaaaaaah!
Old Mar 10, 2006 | 04:07 PM
  #43
BremboGuy's Avatar
BremboGuy
Hey Dave,
Yeah... I'm sure that's the reason.
Most racers are frugal. They get what they can through sponsorships... then they have to buy every thing else.
Racing is an expensive sport.
(I'm off for the weekend chasing the snow...hope you have a great one)
Old Mar 11, 2006 | 12:54 PM
  #44
DZeckhausen
And I'm just through swapping back from winter to summer wheels on my SRT8 after yesterday's 75 degree day in New Jersey! Hope you had a fun weekend skiiing (or snowboarding). Now I had better go prepare for the inevitable blizzard, after having switched to summer rubber.
Old Mar 12, 2006 | 02:41 PM
  #45
DZeckhausen
In case you're wondering - yes the picture did change. The original was one I took at Lime Rock in 2004 (not 2005 as I incorrectly posted). The new photo is from the pits last year at Laguna Seca and shows the StopTech rotors Lou has been running for two seasons and those cheap universal spacers have been replaced with nicer machined ones.
Old Mar 12, 2006 | 06:16 PM
  #46
Zexy's Avatar
Zexy
Ehhh nice? I think stoptech should definately redisign a nicer design/logo on their caliper.
Old Mar 12, 2006 | 06:26 PM
  #47
Zilvia's Avatar
Zilvia
wow ..........6pot fcking sick
Old Mar 14, 2006 | 06:28 AM
  #48
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by DZeckhausen
There is no performance advantage of a leading caliper design over a trailing caliper design. However, there is an advantage in having the caliper as close to the 3:00 or the 9:00 position as possible in order to minimize pad knockback due to wheel bearing deflection under race conditions. See: http://stoptech.com/tech_info/wp_knockback.shtml for more details on knockback. The 350Z (and G35) is more prone to knockback than some platforms because the caliper is significantly above the 3:00 position.
As the wheel, hub, and wheel bearing deflect during cornering,
I would like to know how much deformation is seen on average in cornering if you take an average sports car 3000lb range, I dont know what ball park size bearings are used.
Has Stop Tech done any analysis to correlate this with actual test conditions?
Old Mar 14, 2006 | 06:57 AM
  #49
Kolia's Avatar
Kolia
Yeah, StopTech should re-engineer the whole Z drive train.
Just for fun…
Spiff, are you looking for clues to prove that pad knock back exist? And that it really comes from the wheel assembly’s deflection under cornering load?
Why would StopTech do that kind of research specifically on the Z when they can’t move the caliper around anyways?
Old Mar 14, 2006 | 08:15 AM
  #50
spacemn_spiff
Just for fun…
Before you make condescending remarks, please rethink and stop making assumptions. I have seen analysis done on the similar lines by Bosch for truck brakes. They were not re-engineering the drive train.
Rotor and pad design could somewhat reduce that effect. But that would need lot of detailed analysis and correlation of it. The new Z06 has independant pads for each piston, that should minimize this effect.
Old Mar 14, 2006 | 08:28 AM
  #51
DZeckhausen
There's no such thing as average deflection among sports cars. There is so much variation in bearing design from car to car that you would find some cars quite prone to the problem and others not at all. You need to examine a specific platform. The early WRX STi is really bad, the RX-7 3rd gen (1993-1995) has it, and the Mustang SN95 with a live rear axle gets it bad when you put a fixed caliper in the back. A race team that competes with 350Z (who shall remain unnamed) does blueprinting of bearing and axle components to minimize knockback.
My BMW 540i 6-Speed w/Brembo 4-wheel BBK exhibited medium knockback at a driver's school, but it was consistant and controllable, once I knew it was coming. And my 1996 Impala SS w/4-wheel Mov'it brakes would get it bad going through a sharp hairpin near my house, due to the live rear axle deflection. My 2006 300C SRT8 w/4-wheel factory Brembos does not do it all all.
I believe that StopTech has done some instrumented testing, but not while I was visiting. You'll have to ask them for any test results.
My comment on 350Z knockback comes from driver feedback from pro and advanced drivers running the Track model on R-compound tires and using factory Brembos. The WRX STi is also prone to this phenomenon. It has nothing to do with the Brembo calipers specifically, since a StopTech kit run under the same conditions on this platform would also experience some knockback. It has to do with a combination of brake geometry, caliper design and piston sizing, bearing design, and driving conditions. It rarely happens on the street. It's my understanding that Subaru has upgraded the front bearings on the latest model STi for this very reason.
Old Mar 14, 2006 | 09:24 AM
  #52
Kolia's Avatar
Kolia
The earlier STi would melt the grease in the bearing under the combined effect of heavy load and heat generated by the brakes on a race track. It would fail eventually.
Pad knock back is pretty much something we have to live with on a production based car. Even FIA GT racers will tap their brake before any heavy braking zones, regardless of upgrades.
I get some with my Z on any race track I drive, with street tires.
Old Jul 13, 2006 | 03:41 PM
  #53
dnguyent's Avatar
dnguyent
Well, I'm going to wake this thread up from the dead because I learned something last weekend that I need a bit of clarification from the experts on this board.
I met a racer who is also a regular instructor with a Northern California club. He serves as the technical inspector for the club as well. I allowed him drive my car (w/ 355mm the stoptech kit), and out of courtesy, I warned him that I have knockback issues, and recommended that he pump the brake a bit to set the pads before each turn.
He told me he doesn't have this issue in his e46 M3 that he had ouffitted with aftermarket brembo calipers and floating rotors. When he asked me if the stoptech rotors were floating, I said, "yes". As I understand it, it floats radially to accommodate thermal expansion.
He later elaborated that his rotors also float laterally so that the rotors would give up the gap instead of the caliper pistons. He didn't have his race car there so I could not verify his claims. In any case, do any of you have experience with a rotor that has radial AND lateral float?
It seems that AP racing has a rotor design that supposedly mitigates pad knockback: http://www.apracing.com/roadcar/brakekit/stdrive.htm
I'm working on my left foot tap, but it's downright ugly.
Old Jul 13, 2006 | 04:25 PM
  #54
DZeckhausen
It's not the brakes, it's the platform. The E46 M3 is not prone to knockback, regardless of which aftermarket brake kit you install. The 350Z is. It's a combination of the orientation of the caliper (away from the ideal 3:00 or 9:00 position) as well as the amount of wheel bearing deflection under heavy lateral loads.
Old Jul 13, 2006 | 04:36 PM
  #55
VN_350z's Avatar
VN_350z
DZeckhausen,
In your 350z BBK test, how come you didn't invite other BBK such as BREMBO 355mm BBK or AP Racing?
Why only stoptech vs stock brembo?
Old Jul 13, 2006 | 04:51 PM
  #56
DZeckhausen
Originally Posted by VN_350z
DZeckhausen,
That test was part of the development process of the new StopTech BBK. At the time, there were no other aftermarket brake kits for the 350Z. In fact, the car had not yet been released to the general public. Only the press had driven these cars at that time.
This sequence of testing is done by StopTech to finalize and verify the design of every new kit before it's released for sale. It wasn't a one-time brake shootout. It was part of the normal StopTech development process.
Old Jul 13, 2006 | 04:54 PM
  #57
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
how many miles are on your Z? how many TRACK miles are on your Z?
It may be time to change out your front wheel hubs... It MAY help reduce some of the knock back..
Either way... it was a habit for me on my Z33 to tap the brake pedal out of a hard corner on the straight before the next corner before down shifting...
Plus, the Larger the rotor, the more knock back you may experience... smaller rotors w/ fixed calipers like the OE brembo do not get the same knockback as a 14.1" rotor
Old Jul 13, 2006 | 04:59 PM
  #58
VN_350z's Avatar
VN_350z
There should be BBK shoot out. I wanna see how those stoptech BBK do against big manufactures Brembo, AP Racing, Alcon.....
Old Jul 13, 2006 | 05:19 PM
  #59
Dan@StopTech's Avatar
Dan@StopTech
Default 350Z brake testing
I happened to work for the magazine and be there the day this test happened:
http://www.sportcompactcarweb.com/ro...50z/index.html
The key point is that the car stopped in 99 feet from 60 mph. That's not easy to do on street-legal tires.
I also organized and wrote Road & Track SPEED Magazine's test of tuned Zs last year, including one with Greddy/Grex/Alcon brakes, Stillen's AP brakes, OE base, OE Track and StopTech 355/ST-40 front, 328/ST-22 rear brakes, driving them all at the Streets of Willow back-to-back. If you can find a copy of that magazine (it might have been scanned in here when it came out), you'll see what I said, as well as what the radar gun said about all the others (the StopTech car wasn't at the airfield where the radar work was done). I've driven StopTech and many other BBKs on many different cars, both on track and on the street. I came to work at StopTech because I believe in the product and it's something I can promote fully with complete personal integrity.
-Dan Barnes
Marketing Manager
StopTech
Old Jul 13, 2006 | 07:11 PM
  #60
VN_350z's Avatar
VN_350z
-Dan Barnes
Marketing Manager
StopTech
sure buddy, i believe you
