CAMBERING ISSUE!!! help needed
Old Apr 14, 2006 | 09:05 PM
lilaznxboi08's Avatar
lilaznxboi08
Default CAMBERING ISSUE!!! help needed
im so pissed off. so to start i have some rims ok, and lowered it with eibach pro kit. so after about 26k miles my front driver side tire blows at a stop light so i pull over change it n i see a lump that blew open. so yea just get a new tire but i checked the rest of my tires n the inside is bald and the outside has alot of thread. so i got the tire put on and my rim that blew is bent, and im assuming there was so much pressure on the inside it bent my rim. so i got it fixed and i was wondering what you guys think i need to do? im thinking of getting a camber kit for the rear and just getting allignment and maybe that will fix the front. i appreciate your help.
Old Apr 14, 2006 | 09:12 PM
changsw's Avatar
changsw
Yeah, when your tires are that bad, I would get a camber kit. Mine are not as bad, but I've had camber issues with previous cars too. Get one, you won't regret it. The only downfall with Z camber kits are their prices. SPC makes one of the best rear kits and they are working on a some front ones now. We should see something from them in a month or so. I'm waiting for their front kits so that I can buy both front and rear at the same time. Good luck man.
Old Apr 14, 2006 | 09:14 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
As soon as you drop your car, you will need camber kit to bring it back to spec.
Old Apr 14, 2006 | 09:23 PM
lilaznxboi08
alright yea i was thinkn about the spc for like i think 200 for the rear. but should i just not worry about the front right now. thanks alot guys.
Old Apr 14, 2006 | 09:29 PM
changsw's Avatar
changsw
Well, you want to have some camber anyway so your car will handle like it should. If you have all four wheels with perfectly zero camber, it won't be the same. I've yet to determine what is a good camber angle after the installation of camber kits, but I do know that you're going to need some negative camber. I was thinking something like 1.2 in the front and 1.4 in the back. I dunno though.
Old Apr 14, 2006 | 09:33 PM
Visit a alignment shop and have the car checked. Can it be adjusted to bring it into specs? If no, then you will have to buy kits for the front or rear or both.
Old Apr 14, 2006 | 09:58 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
align your car first then see if you need the front or not.
+1 on SPC rear. Good stuff.
Old Apr 14, 2006 | 10:05 PM
Super Avan Z33's Avatar
Super Avan Z33
There are zero adjustable for the stock front camber, so whenever we lower the Z's, we do need some adjustable one for the front. But someone said there's no need to replaced the rear, because the rear is the adjustable one, there is some chance we could probably realign or readjust to bring them back to spec, correct me if am wrong.
Old Apr 15, 2006 | 04:07 AM
nashjam's Avatar
nashjam
+1 on getting an alignment first. I have eibachs and my right front is about 0.2 degrees out of spec. The left front is barely in spec. Since I'm not so far out of spec, I can't justfiy the expense of a camber kit at their current costs. I just regularly inspect my tires. Also 26k on a set of tires doesn't seem to be all that bad considering some post about getting less than 18k.
Old Apr 15, 2006 | 01:24 PM
zredline's Avatar
zredline
I found the spc camber kit for $140 at NOPI, look in the special sale items for the 350Z.
Old Apr 15, 2006 | 06:04 PM
nashjam's Avatar
nashjam
Ah $140 that's awesome, I'll have to check that out. The only available camber kit I knew of was Cusco and they run about $600.
Old Apr 15, 2006 | 07:35 PM
zredline's Avatar
zredline
Ok sorry $140 is for the rear camber kit not a front kit.
Old Apr 15, 2006 | 07:57 PM
nashjam's Avatar
nashjam
Yup, I just looked it up...Front camber kits are expensive.
Old Apr 15, 2006 | 08:58 PM
Super Avan Z33
$140 a set of 2 for both rear wheels or just 1 wheel?
Does they included the toe bolt or not?
Old Apr 16, 2006 | 03:57 AM
zredline's Avatar
zredline
I order it and I have not received it yet, it is $70.07 each. From the wording it appears to include the bolt.
076+1649 Suspension Alignment Component SPC PERFORMANCE Performance Alignment Kit - Rear EZ Arm and Toe Cam - Camber Adjustment Range +/- 4.00 degree - Toe Adjustment +/- 3.0 degree - 2 required $70.07 - Kit
Old Apr 16, 2006 | 07:36 AM
mxjosh711's Avatar
mxjosh711
i have the eibach kit here in my bedroom .... now i dont want to put it on after reading this :/
Old Apr 16, 2006 | 11:37 AM
lilaznxboi08
dang thanks guys, alright ima get an alingment n talk to those guys about it, they have horrible english so damn.
Old Apr 16, 2006 | 11:46 AM
lilaznxboi08
can you guys link me to the nopi site to buy the parts ive been looking and cant find anything.
Old Apr 16, 2006 | 03:02 PM
zredline's Avatar
zredline
http://www.nopionline.com/nopistore/...TOKEN=51218244
Old Apr 17, 2006 | 09:32 AM
Super Avan Z33
No luck, too bad for me that they don't have it anymore when I called them try to place an order, special sale alway like this, maybe we should start a group buy for our need, anyone interesting or have better idea?
