Have aftmkt rear camber arms...come in here!!!
Old Apr 18, 2006 | 08:59 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by MIAPLAYA
The SPC toe bolt write up was lost on my server but I think protocav may still have a copy. I'll see if I can get it from him if you need it. Trust me and everyone else here, don't waste money on Kinetix or 350 Evo. The SPC units work the best for the least amount of money. The traction arms are absolutely the worst way to adjust toe. When they do adjust it at the same time they alter rear caster and stress the entire assembly. The only PROPER way to adjust toe is to change the position of the spring bucket which is done with the SPC toe bolts. For front camber absolutely the EVo A arms are the way to go. For the rear the SPC offers everything you need at the abolsute best price on the market.
for some, paying top money meaning they get the best. *sigh*
Old Apr 18, 2006 | 09:51 PM
sja177's Avatar
sja177
I would also change the suspension to Tein Flex, the ride is solid, very very stiff, but if you can take the beating it will help you more than the nismo im sure, let us know which arms you get and how you like them, im also in your boat and need more traction from the rear.
Old Apr 19, 2006 | 06:17 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I have no desire to lower the car any more than it already is. The tein coilovers will be too stiff to provide weight transfer when launching the car. Not to mention it already handles and rides great with the Nismo when I'm not running a DR in the back.
I ordered the SPC arms last night...I'll have a write-up for them done in the next few weeks.
Thanks for all the help guys!
Old Apr 19, 2006 | 07:05 AM
MIAPLAYA's Avatar
MIAPLAYA
Grats...you won't be disappointed. Let me know if you need me to dig up the toe bolt write up that protocav did...He has some good data in there including what exact Dremel bit you need, etc.
Old Apr 19, 2006 | 10:03 PM
overZealous1's Avatar
overZealous1
yes , i have the spc's also. you will definately need the toe bolts as the Z suspension has a TON of toe gain if you lower the car at all. i am dropped 2.5" in the rear and i have maxed out my spc toe bolts and can still only reach about -1 to -1.5 degrees camber in the rear. without those toe bolts, i would have to still be around -3 or more on camber or suffer wicked toe in. you will see what i mean if you do the install yourself. it can be frustrating setting camber and toe as a small adjustment on one will adversely affect the other.
Old Apr 20, 2006 | 03:00 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
my car is only lowered 20mm...so that's not an issue. I want to get rid of ALL of the negative camber (-1.4 degrees right now with the stock setup) for better traction. I might go back to a handling setup later, but this will be all straight line.
Old Apr 25, 2006 | 11:35 AM
gringott's Avatar
gringott
NOPI has the SPC on sale for $70 each, $140 for two, in the 350z special sale area. To be sure it is the same here is the write up:
NOPI part number 076+1649
Performance Alignment Kit - Rear EZ Arm and Toe Cam - Camber Adjustment Range +/- 4.00 degree - Toe Adjustment +/- 3.0 degree - 2 required
Old May 3, 2006 | 12:21 AM
sokudo9l6's Avatar
sokudo9l6
so are they the same part? I'm going to order them from nopi if they are!
Old May 3, 2006 | 02:48 AM
gringott's Avatar
gringott
Don't know if it is the same, but the part is off the special list and is now $78 each, a $16 jump for two. Maybe too many people from here ordered already. I should have ordered when I found it.
Old May 3, 2006 | 08:10 AM
gringott's Avatar
gringott
Default NOPI part number and price
I emailed NOPI and here is the answer:
72050 is 076+1649. It is now $78.69 each
Thank you,
Martin @ NOPI
800 277 6674 ext 263 inside USA
404 608 7999 ext 263 outside USA
That means that it is the Pro Series 350Z Extreme Rear Kit, and it is off sale and now about $17 more.
Attached Thumbnails Have aftmkt rear camber arms...come in here!!!-72050.jpg   Have aftmkt rear camber arms...come in here!!!-72050ill.jpg
Old May 3, 2006 | 08:58 AM
HoldThisForMe's Avatar
HoldThisForMe
Just ordered my kit from nopi. With just ground shipping it was 169 and some change. not bad at all. Now I just have to hide them from my gurl until i get my car back haha
Old May 3, 2006 | 02:18 PM
sokudo9l6's Avatar
sokudo9l6
^ let us know if it is the same kit.
Old May 3, 2006 | 05:05 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Its the same part. I bought 20 of them from NOPI last year for a GB.
Old Jun 19, 2006 | 12:01 PM
JhayRCruz's Avatar
JhayRCruz
damn..20 kits?? Tryin make a profit or do u have a performance shop? Let me get a set lol.
Old Jun 19, 2006 | 12:07 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
We did a GB for our local club. I didn't make squat.
NOPI has a low everyday price though. Check 'em out if you want some.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
