Factory Camber Adjustments?!?
Old Apr 25, 2006 | 09:20 AM
plastiketa's Avatar
plastiketa
Default Factory Camber Adjustments?!?
Just got my car aligned and noticed that the front camber setting were not touched. The technician claims that there is no way to adjust camber for our cars from the factory. Is this true? Does anyone know if there is a way to adjust the front camber settings without getting aftermarket a-arms?
Old Apr 25, 2006 | 09:25 AM
MoodDude's Avatar
MoodDude
He is right - no factory camber adjustment - just toe.
You are stuck getting aftermarket a-arms (well I guess you could change the ride height, that would change the camber too.)
Old Apr 25, 2006 | 09:26 AM
mpowers's Avatar
mpowers
Correct no factory camber adjustments. Don't believe there is any other way than aftermarket upper control arms.
Old Apr 25, 2006 | 09:41 AM
plastiketa's Avatar
plastiketa
Thanks for the input. Now I have a new dilemma:
Cusco A-arms or Kinetix A-arms??
I don't want to spend crazy amount of money on these. I know Stillen and 350evo make REALLY good arms, but its a bit to pricey for me. My main concern is trying to try to bring the camber back or as close to spec as possible. I don't plan to do some track time but if I ever do (which is highly possible), I would like to know that they can survive the onslaught.
Any suggestions? First hand experience would be a great help.
Thanks again.
Old Apr 25, 2006 | 10:01 AM
~~O8>'s Avatar
~~O8>
I bought the Cusco's they are very well made and can be had for under $400, but they don't give you enough positive camber adjustment. If you drop your car more than 1.5" its not cutting it, the EVO arms are your best bet. Spending the extra $350 will save you alot of tire money in the long run.
If i had to do it again I would go EVO A-arms.
Old Apr 25, 2006 | 10:08 AM
Alang35's Avatar
Alang35
if youre really in a bind, you can get cusco arms and modify them to accomodate more adjustment.
Old Apr 25, 2006 | 11:35 AM
Super Avan Z33's Avatar
Super Avan Z33
How about Kinetix A-arms? are they good?
Old Apr 25, 2006 | 03:09 PM
plastiketa's Avatar
plastiketa
Have you seen or heard anyone modding them to do so? sounds like a good idea, but I'd be concerned with compromising the integrity of the arms.
Do they mod the sliding plate with a drummel or something?
Old Apr 25, 2006 | 04:14 PM
caucasiancoupe's Avatar
caucasiancoupe
I'm getting the kinetex installed tommorrow at the infiniti dealer in riverside cali. I'll let you know in a couple days.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Depravity
Oct 1, 2015 04:49 PM
