Who has a BBK with Volks GTC 19x9.5 +21 & 19x10.5 +24?
Old May 19, 2006 | 08:47 AM
maximumsportZ's Avatar
maximumsportZ
Default Who has a BBK with Volks GTC 19x9.5 +21 & 19x10.5 +24?
I'm looking around for a BBK for my Z, but I'm not too sure what will fit with my rim setup and have no issues. I would like to hear from some others.
Also not sure how many pistons I want to run, whats good for daily? I'll probably run a 14" rotor.
And also what should I run for the rears as I would like to match the front ones up.
Thanks.
Old May 19, 2006 | 11:04 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
We have wheel fitment templates for all of our 350Z kits avialable for download on our website:
http://www.stoptech.com/tech_info/wheel_fitment.shtml
Print them out and put them in the wheel to see whether or not you will have any clearance issues. FYI, our 6 piston caliper uses shorter length pistons and actually has a few mm more clearance than our 4 piston caliper. Both calipers will have the same torque output for optimal balance so street performance betwen the two will essentially the same.
Old May 19, 2006 | 11:13 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Thanks.
What offset and face type is it? You can use StopTechs wheel fitment guide or if you know your specs on your wheels I can also tell you. For daily driving, Id recommend the StopTech 14.1 4 Piston front/12.9 2 Piston rear and a variety of pads you can use. Youll have a neutral, balanced braking system with that setup. We also carry Project Mu, Endless, Brembo, AP BBK's if you are looking for something else.
Old May 19, 2006 | 11:33 AM
Nitrouz's Avatar
Nitrouz
Back to Z
I have a less aggressive offset than you. 19x8.5f +27 and 19x9.5r +24 and I have stoptech 14.1" both front and rear. You'll be fine.
Old May 19, 2006 | 11:52 AM
Andy@Performance
Performance Nissan
GT-S on yet?
Old May 19, 2006 | 07:24 PM
Nitrouz's Avatar
Nitrouz
Back to Z
still waiting...
coming sometime next week.
Old May 19, 2006 | 07:36 PM
VN_350z's Avatar
VN_350z
My Te37 (18x8.5) with +22 offset is able to fit Brembo GT 14 inch kit
Attached Thumbnails Who has a BBK with Volks GTC 19x9.5 +21 & 19x10.5 +24?-350z_brake_small.jpg   Who has a BBK with Volks GTC 19x9.5 +21 & 19x10.5 +24?-z1.jpg
Old May 19, 2006 | 07:47 PM
Nitrouz's Avatar
Nitrouz
Back to Z
how does that have anything to do with his GTC fitment??
