coilover question
Old May 22, 2006 | 06:30 PM
glogan's Avatar
glogan
Default coilover question
I did a search and found no answer to my question..
I just got done installing my coilovers and was wondering how you adjust the manual damper **** without pulling the rear suspensions out again? Which panels do I remove in the trunk?
Thanks
Old May 22, 2006 | 08:57 PM
350Zteve's Avatar
350Zteve
Thanks
The top of the rear shock comes out inside the rear strut bracing and is completely encased in sheet metal. Some people drill a hole through the panel and sheetmetal and make a tool to reach all the way inside to adjust the shock, but its not easy.
Old May 22, 2006 | 09:47 PM
glogan's Avatar
glogan
Default thanks
Thanks... got some more figuring out to do...
Old May 23, 2006 | 07:32 AM
konspec's Avatar
konspec
drill a hole in the rear strut brace right over the **** then use a long allen key. 15min fix
