Brembo Brakes
May 16, 2006 | 04:03 PM
Brembo Brakes
Are the mounting point the same on brembo brakes as the stock brakes, or do I need a addapter?
May 16, 2006 | 05:26 PM
same, rear bolts are a little different.
May 22, 2006 | 08:53 AM
I have an 05 Touring w/o brembo, can I get the OEM brembo calipers and roters and swap them or is there some modificatio needed?
May 22, 2006 | 09:23 AM
Need longer bolts as mentioned above, stock brembos lines (or SS Lines), and you'll have to cut the rear dust shield for the new rotor to fit
May 22, 2006 | 11:26 AM
Quote:
ya or just bend the crap out of it
May 23, 2006 | 06:49 AM
...or you could buy the correct dust shield for about $55 each.
May 23, 2006 | 07:31 AM
then you would have take the hub off and thats a pain in the *** for something you will never see once the brembos are on
May 23, 2006 | 10:26 AM
So I have a question, if this is true and you would only need longer bolts, can we bolt on the Racing Brake Big Brake Upgrade made only for the 350Z Non-track and G35 Auto, and use the OEM brembos calipers?
May 23, 2006 | 10:43 AM
Quote:
F that
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
