Twisted chassis? Poor spring installation? opinions
Old May 25, 2006 | 03:50 PM
tienlo's Avatar
tienlo
Default Twisted chassis? Poor spring installation? opinions
Heya, I've just realised that my car sits a few millemetres (approx 1/4 inch) higher on the Left Front and Rear Right (ie opposite corners). I'm simply measuring the distance from the center of the wheel to the top of the wheel arch. It's quite noticeable too when you look at the gap between the top of the wheel arch and the top of the tyre.
I've put Trust Dowmax progressive springs in the car and sway-bars. Wheel alignment has never been a problem, with equal camber / toe / caster on both sides of the car. I'm not aware of the car being in any crashes but i did buy it as a demo vehicle with approx 8000 miles. The car drives fine. It's RHD because i'm in australia.
I'm also aware that some brands of lowered springs are intentionally 5mm or so taller on the driver's side to compensate for weight.
So... what do you guys think? Is this normal? Is my chassis twisted? or do you think it's something fixable eg re-installing springs / sways etc.
Old May 25, 2006 | 03:52 PM
sq40's Avatar
sq40
Are you sure the Ground is Level?
Old May 25, 2006 | 05:11 PM
tienlo's Avatar
tienlo
definitely. I've measured it several times with the car in flat concrete garage, with the car positioned in all directions (because i thought that might be the problem) and the result is the same.
Old May 25, 2006 | 05:19 PM
Driver06's Avatar
Driver06
I doubt your chassis is twisted, but anything is possible.
Did you make sure that your springs are sitting properly in the cups?
Old May 25, 2006 | 05:39 PM
sq40's Avatar
sq40
One of Ubermench's Girls didn't flop down in your seat did she?
Really though, I would have all of components checked out, sometimes they forget a bushing or two.. How long have you had the mods? Maybe they need to "Settle".
Old May 27, 2006 | 06:19 AM
Gsedan35's Avatar
Gsedan35
Looking at Z's and G's over time, where owner's have actually tape measured their ride heights. It is common to see such a differance in ride height in. On the whole, the rear is far more likely to be where the differance is seen and generally it is usually limited to one corner. Can't really say I've heard of a whole side being higher.
If a spring system is using differing drop amounts to effect corner weights, in the absense of the car being on corner scales at the time of install,.....how on earth do you know where to make a adjustment? I'd like to read how that brand sell's that type of idea.
Old May 28, 2006 | 08:36 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
unless your car was t boned by a dump truck, the chassis is fine
it is totally normal for a car with aftermarket springs to sit slightly differently front to back and side to side
I have never heard of a spring intentionally being higher on the driver side to account for driver weight...that makes zero sense
