negative camber ?
Old Jun 19, 2006 | 06:29 PM
david5679's Avatar
david5679
Default negative camber ?
i dont get it --- i buy a 6 hundred dollar camber kit and big O tells my because the car is lowered over an inch it well always have neg camber and tires will only last 10-15k miles--- anyone else here this bs ??????
Old Jun 19, 2006 | 06:32 PM
lex350's Avatar
lex350
Sounds like BS to me. Go somewhere else.
Old Jun 19, 2006 | 06:47 PM
drumma022's Avatar
drumma022
The factory service manual says the Camber range on the Z should be 0.17deg to -1.3 deg for the front and the rear should be -1.0deg to -2.0deg.
Also, toe is the major factor in tire wear. My car, when at .75" total toe and 2 deg camber for the rear destroyed tires in 3000 miles. When at 3deg camber and 0 total toe, the tires have more than 10000 miles with a good amount of tread left.
Old Jul 6, 2006 | 11:36 AM
06Firebase's Avatar
06Firebase
Question Newbie question
Can I ask some beginner questions here, please?
I notice that on my car (and other Z's I've seen) that the rear wheels seem to tilt inwards at the top. Is that what they mean by "negative camber"?
Or is this an optical illusion b/c of the rounded body shape, etc?
Also, is there any difference between "camber" (on the front wheels) and "steering axis inclination"?
I'm trying to catch up on this stuff.
Thanks,
joe
Old Jul 6, 2006 | 11:44 AM
Yellow Stealth's Avatar
Yellow Stealth
Take a look at the TireRack's writeup on alignments: http://www.tirerack.com/tires/tirete...currentpage=39
Old Jul 6, 2006 | 12:10 PM
06Firebase's Avatar
06Firebase
Hey Yellow Stealth! Thanks for that link. That'll shut me up and keep me busy for awhile. I'm trying to learn as much as I can, as fast as I can. OK, so it IS negative camber on the rear then.
Now I know I'm a "reserved driver" (at this time, anyways )
All best,
Joe
Old Jul 6, 2006 | 04:05 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Why do you want to get rid of negative camber? It helps the car....only truly excessive amounts hurt (we're talking 3+ degrees) in terms of wear, and even then, its primarily hurting you if you do nothing but drive straight
As for your tire wear, its all about how you drive, and what tires you are running
I got 30k out of a set of T1S running gobs of camber (over 2 degrees front and rear)
Old Jul 6, 2006 | 08:49 PM
FrickU's Avatar
FrickU
You will always have a little bit of negative camber if you lowered the car, with shocks, springs, coilovers...etc
I have a bit of negative camber on my car which is running tokico's and sportlines, and it's not that big of a deal. That is the sacrifice...Those camber kits help a little bit but, they aren't going to get rid of the camber.
And having negative camber is better performance wise. But if you are worried about the mileage you are going to get out of the tires, just be careful with them, and don't do any drifting
Old Jul 7, 2006 | 07:24 AM
Z1 Performance
Former Sponsor
not only withe springs/coils the car has negative camber from the factory. Dial it out and the total feel of the car is lost
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
