Slotted vs Drilled
Old Jun 29, 2006 | 01:57 PM
  #41
350Zteve's Avatar
350Zteve
How about some 2006 stock brakes? I've seen some deals on them with barely any miles. They are 1" bigger or so on all 4 corners. Those and some good pads would be great for less money.
I hope you're not planning on running skinnies in the front. Those destroy your stopping distances on heavy cars.
Old Jun 29, 2006 | 02:01 PM
  #42
mrtomcat's Avatar
mrtomcat
no I'm not doing the skinny route just yet. If I ever turn the car into a full race car then yes but not at this point
Old Jun 29, 2006 | 02:06 PM
  #43
Chebosto's Avatar
Chebosto
? for X drilled 14" rotors..
i've been to buttonwillow w/ Pagid Oranges on the ST40s.. and did several triple digits slow downs repeated throughout the day... i check my brakes quite regularly, and i find no signs of cracking or fatigue on my X drilled rotors.
how much temperature fluxuation are we talking about for X drilled rotors to see adverse affects? i do remember doing cool down laps after each session...
Old Jun 30, 2006 | 02:08 PM
  #44
J Ritt's Avatar
J Ritt
Cheston,
When you're going as slow as you are, you aren't going to notice much difference between slotted and drilled...**ducks and runs***
Seriously, just give them time and some more track days and they will start to crack around the holes. You'll probably also start to see concentric grooves developing. They can withstand quite a beating though. I used to show up at track days with all sorts of cracks in my rotors, but they were all in the center of the rotor, and not a big deal. People were like, "man, shouldn't you replace those!?!?!" Once the cracks are out on the edge, or down at the hat attachment and you can hang a fingernail in them, then you need to get some new iron.
Here are some rotors of ours that went the full 25hrs. of Thunderhill...these are sort of what mine looked like when I took them off:
Your other option Cheston is to just let me drive the car for a few laps...I'll do them up right for you with that turbo setup...
Old Jun 30, 2006 | 02:27 PM
  #45
Chebosto's Avatar
Chebosto
Originally Posted by J Ritt
Cheston,
Old Jul 4, 2006 | 12:18 PM
  #47
techcontrol's Avatar
techcontrol
I have drilled and slotted, but not by choice. AP only offers the 4 piston F & R with 13" drilled and slotted only. So far, no issues with cracking or non-performance. Just the normal low speed squeal.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
RWDBajan
Sep 17, 2015 04:52 PM
3vilbunny
Sep 13, 2015 12:31 PM
