How long does it take to install the SPC Rear Camber Kit
Old Jul 5, 2006 | 02:50 PM
mrtomcat's Avatar
mrtomcat
Default How long does it take to install the SPC Rear Camber Kit
I'm finally getting my SPC rear camber kit installed and was wondering how long this should take?
I heard that drilling out for the Bolt is a pain in the ***.
Any info?
Thanks
Old Jul 5, 2006 | 02:56 PM
dirtroad's Avatar
dirtroad
it's the easiest mod you'll ever do - just make sure you have a high-powered dremel to cut out the hole (nice DIY on here somewhere for that). the arms are very simple. just make sure there is roughly the same amount of thread on each side of the adjustment ****.
Old Jul 5, 2006 | 03:06 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
a shop quotes me from 1-2 hours.
Old Jul 5, 2006 | 03:07 PM
mrtomcat's Avatar
mrtomcat
I'm having it done at performance nissan but want to make sure I have an idea of how long it will take.
Old Jul 5, 2006 | 04:48 PM
MIAPLAYA's Avatar
MIAPLAYA
Its an hour job...heres the write up for it
https://my350z.com/forum/brakes-and-suspension-diy/185737-spc-toe-bolt-install-write-up-with-pics-courtesy-of-protocav.html
BTW protocav can do this for VERY cheap down in SD and has done tons of them. Every Z/G in SD with this done had it done by protocav...
Old Jul 5, 2006 | 06:45 PM
Elite 350z's Avatar
Elite 350z
Im gettin these as well, im dropped on Tein Type Flex and right now my rears are DEF out of spec, do i need the rear arms or could i just get through with the toe bolts alone??
Old Jul 5, 2006 | 07:35 PM
MIAPLAYA's Avatar
MIAPLAYA
You should honestly get both... FOr the low cost of the SPC units you might as well.
Old Jul 5, 2006 | 07:53 PM
mrtomcat's Avatar
mrtomcat
thanks guys!
Old Jul 5, 2006 | 09:58 PM
mrtomcat's Avatar
mrtomcat
one more questions:
I currently have 255/45/17 in the rear which will continue to use for drift days but am getting 295/35/18 for day to day this week; I also run the 26 x 10.5 x 15 Slicks at the track
will my camber/alignment be affected by that or do I not need to worry?
Old Jul 6, 2006 | 03:08 AM
Elite 350z's Avatar
Elite 350z
IAP Direct has them for $219 for both, is that a decent price or are there cheaper places than that??? thanks guys
Old Jul 6, 2006 | 03:26 AM
Julian@MRC's Avatar
Julian@MRC
About 1-2 hours labor but you MUST go immidiately for an alighnment or the car will feel like the rear end is loose..
Old Jul 6, 2006 | 04:40 AM
drsifu's Avatar
drsifu
elite_350Z...
there are places cheaper than that, roughly 20% cheaper
but to earn the low price, you must search.
and i'm not talking about a private seller...i'm talking about a nationally recognized online retailer.
good luck
Old Jul 6, 2006 | 07:16 AM
MIAPLAYA's Avatar
MIAPLAYA
Nopi used to have them cheaper...that being said I got mine at IAP Direct...
Old Jul 6, 2006 | 07:17 AM
MIAPLAYA's Avatar
MIAPLAYA
Thats noted as well at the end of protocavs write up. In some cases your slip light will even come on as the rear tires are scrubbing so bad the ECU thinks you are slipping...
Old Jul 6, 2006 | 10:19 AM
mrtomcat's Avatar
mrtomcat
anyone have an answer on my question in regards to different tire sizes?
Old Jul 6, 2006 | 10:51 AM
MoodDude's Avatar
MoodDude
Hey - I don't have SPC rear camber arms - I thought you where trying to buy exactly what I have? Just - joking.
Your camber will not be effected by different wheel sizes, but you may want to set up different cambers for the different driving styles. For steet, 0 to -0.5 is ideal, for drag you want as close to 0 as you can get, for drifting I believe the ideal is around -1.5.
Old Jul 6, 2006 | 12:22 PM
mrtomcat's Avatar
mrtomcat
Damn did my spy network fail me on that one?
from what I understand is that 0 is perfect for drag racing, -2.0 is stock and -1.2 is as high as nissan recomends as a valid camber.
Don't you have to get an alignment everytime you change the camber settings?
Old Jul 6, 2006 | 12:29 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes. Changing the camber will affect the toe of the wheel too. However if you could mark each setting accurately you could probably adjust each time to a pretty close setting. Camber at the strip should be close to 0. Maybe -.6, -.7 But that will yeild crappy cornering... -1.5 works well for me for handling and dialy driving...
Old Jul 6, 2006 | 12:33 PM
JDMFairlady21's Avatar
JDMFairlady21
very good info on this thread... noobs should read this.
Old Jul 6, 2006 | 12:51 PM
Elite 350z's Avatar
Elite 350z
IAP was a little more expensive but Peter price matched and gave me them for $180 shipped, this is rear camber + toe bolts...anyone lookin to get these Peter from IAP will take care of you...
