what spring drop wont need camber kit?
Jul 11, 2006 | 01:20 PM
guys what are my options for drops on my 06 that won't need a camber kit? i've read that anything more than .75 and I will be needing a camber kit, is this true?
Jul 11, 2006 | 01:24 PM
I'm using tein s-techs. Didnt need a camber kit. I think the drop is about .6-.7 all the way around. Not a slammed look but perfect for me....drew
Jul 11, 2006 | 01:32 PM
I have Tanabe GF210.
1" front snd 1.2" rear drop.
No problem whatsoever; just needed 4 wheel allignment.
Jul 11, 2006 | 02:03 PM
Did they get the alignment to factory specs or was it "close"?
Jul 11, 2006 | 02:38 PM
wow 1" and 1.2" no camber? how long has it been? and no thread wear issues? and how about the allignment they got it close to specs?
Jul 11, 2006 | 03:35 PM
Quote:
Thats what I wanted to ask.
Jul 11, 2006 | 03:37 PM
Quote:
depend on the wheel offset also.
Jul 11, 2006 | 04:59 PM
1 inch drop will need toe correction for sure...no way around it, even with stock wheels. Camber will be more than stock, but not bad.
RSR was a good option, but cannot be had, at least for the time being till they are reorganized. S Tech's are a good option and work very nicely on the Z
Jul 11, 2006 | 07:09 PM
you guys got a pic of the s-tech drop?
Jul 11, 2006 | 07:28 PM
Espelir GT Spring.. 0.6" drop... spring rate is really good too.. and is really made in Japan..
Jul 12, 2006 | 06:47 AM
my hotchkis got back in spec without a kit
Jul 12, 2006 | 06:49 AM
The Nismo spring and shock setup does not need a camber kit at all. I got it aligned to almost factory specs.
Jul 12, 2006 | 08:47 AM
+1 For the GF210, fantastic spring. Almost a year with them on, no issues whatsoever. Has the perfect drop. Do a search on them, have yet to see a negative review.
Jul 12, 2006 | 12:47 PM
you won't need camber kit with the gf210?
Jul 14, 2006 | 05:34 AM
Hotchkis
HoBrahYouStink
Jun 24, 2016 10:58 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
camber ,
camper ,
drop ,
dropped ,
inch ,
kit ,
lowest ,
my350z ,
require ,
spring ,
springs
