Crown SS brake line's, am I missing bolts???
Old Jul 23, 2006 | 04:46 PM
Axelerate's Avatar
Axelerate
Default Crown SS brake line's, am I missing bolts???
I've had these SS lines from Mossy for a while and I was planning on installing these tomorrow. After doing some searching about installing brake lines I think I'm missing the bolts.
I received:
Front and rear brake lines
4 copper washers
front clips
front mounting guide thing
I saw a pic of some of the other kits and they come with the pass through bolts. Is it possible to use the stock ones or am I just screwed?
I am leaving for a track event on thursday and doing all my brake work tomorrow.
So please give me some feedback from those who have installed the lines. I searched and found 0 info about these lines.
Thanks for the help!
Old Jul 23, 2006 | 05:16 PM
spacemn_spiff's Avatar
spacemn_spiff
If you dont have any hold down clips, then you could probably buy them at Home Depot or a hardware store.
I have Stoptech SS lines, they came with one clip instead of 2 needed for the Z. One fits on the linkage between two wishbones and one on the strut. This can cause rubbing issues in extreme turning situations for me, which are rare thats why I am not looking to do anything about it.
Old Jul 23, 2006 | 05:46 PM
Axelerate's Avatar
Axelerate
I have the clips, I'm mainly worried about the bolts.
I did not receive any, and I have no idea if I can reuse the stock ones or not? If not, can I buy the bolts at a autoparts store?
Old Jul 23, 2006 | 07:36 PM
ht4's Avatar
ht4
I got the goodridge lines and they came with new banjo bolts... but I don't think that matters -- its been a while since I had the brakes off, but I think the stock bolts will work, and there is no problem with reusing them.
The only important parts to replace are the copper crush washers. Sounds like you are 4 short (need 2 on each caliper). But no worries: these can be bought for about $.05 each at Pep Boys.
