Is Nissan's warning about VDC equiped vehicles true?
Is this note actually true or is it just nissan BS way of trying to get more money from you. Lets say you have a VDC touring model and decide to put aftermarket Volks. Will you VDC not work due to your new lightened rims??? What if you have Eibach springs and Volk wheels with no sway bars? Does your car slip out of control or loose straightline power because your car always thinks something is unbalanced?
Thanks
Performance Nissan
Performance Nissan
you can do anything you want with the suspension etc...
as long as the tire diameters are relitive to stock size....
ie:
245/40/18 / 275/40/18
245/35/19 / 275/35/19
265/35/18 / 295/35/18 etc etc
ie:
ie:
ie:
front-17 x 19.5 rim with 255/40R17
rear- 18x10.5 rim with 265/35R18
i was planning on running this like the concept RS car. is this cool? thanks bud
Performance Nissan
Performance Nissan
If you do the 255/40/17 up front, you should run 275/35/18 in the rear...
you want around .6" difference in diameter
depending on overall size that is... in this case... the above is what you want...
Performance Nissan
Performance Nissan
Originally Posted by eat rice z33
oo do you think the RS concept has 265 rear for better turn in perhaps?
you can do 275 on the front no problem...
im talking about the nismo RS concept S1 the one with the canard nissan bumper and the v1 wing and the infamous rear diff oil cooler
https://my350z.com/forum/showthread....smo+concept+RS
Performance Nissan
Performance Nissan
im not 100% familar with that car, but I believe that has 18x9.5 LMGT4's all around w/ 275/35/18 all around... that will effect VDC...
we do 275/35/18 Front / 275/40/18 Rear
like this...
like this...
So any increase must be proportional to front and rear. So +20 in width on front should be also +20 in rear tire?
Now what happens if you have nismo suspension and rims but no sway bar? Does that really affect anything?
Performance Nissan
Performance Nissan
as long as you have the correct ratio between front and rear you can have any size...
you can do any part of the suspension seperately... suspension and wheels only... or wheels and sways only... etc etc... the only thing that that matters is that the tire size is slightly larger in the rear (overall diameter) then the front...
Technically, the computer must see the staggered difference, but in all reality its on a per car basis. I run 265/35/18 on all for corners and my VDC/TCS functions as normal. No problems at all.
Have you guys actually experienced VDC difficulties running non-stagger?
I've run non-stagger for close to 3 years and I've had ZERO VDC issues. Regardless of tire make/size (same size all round), VDC has worked like a charm - especially during the winter with snow/ice covered roads...
In fact our local Infiniti dealership sells non-stagger winter wheel/tire packages for G35 with VDC...
19
Z/G Owner:
No
Biography:
Back Yard Customs
Bronx, NY
Interests:
Making Custom Modifications
Occupation:
Electrical Engineer
We will figure it out when you get a 350Z.
19
Z/G Owner:
No
Biography:
Back Yard Customs
Bronx, NY
Interests:
Occupation:
Electrical Engineer
Performance Nissan
Performance Nissan
Ive been in cars that peoplehave had 245/35/19 / 275/30/19 and under hard acceleration the car sputters and vdc comes on...
there is a way to re-calibrate the system....
Originally Posted by davidv
19
Z/G Owner:
No
Biography:
Back Yard Customs
Bronx, NY
Interests:
Occupation:
Electrical Engineer
19
Z/G Owner:
No
Biography:
Back Yard Customs
Bronx, NY
Interests:
Occupation:
Electrical Engineer
Thank you
Originally Posted by Z1 Performance
The RS Concept uses 17x9.5 front, 18x10.5 rear with 255/40/18 front, 265/35/18 rear, but in an R compound (A048)
