Nismo Solid Sway Bars
Old Feb 27, 2003 | 09:55 AM
tomsn16's Avatar
tomsn16
Default Nismo Solid Sway Bars
What is the diameter(in mm) of the Nismo front and rear bars?
Old Feb 27, 2003 | 10:06 AM
johnlotusboy's Avatar
johnlotusboy
I believe they are the same as stock, but the wall thickness is greater making them stiffer. They are hollow just like the originals.
Old Feb 27, 2003 | 12:52 PM
jran76's Avatar
jran76
Default Re: Nismo Solid Sway Bars
35mm Front, 22mm Rear, they are hollow and probably about 20% stiffer than stock. The R-tune will be stiffer and maybe solid. Cusco makes some that are solid, the same size as the Nismo, less expensive, and adjustable.
Old Feb 28, 2003 | 01:10 PM
tomsn16's Avatar
tomsn16
I called Finishline re the Cusco bar and they said nothing was available yet for the 350Z. Any ideas on who to contact and how for a 350 front bar???
Old Feb 28, 2003 | 01:36 PM
jran76's Avatar
jran76
www.gruppe-s.com
Check the classified section of this site, he posted the price and pics, they look nice (in Blue). Cusco is top quality.
Old Feb 28, 2003 | 04:25 PM
dwnshift's Avatar
dwnshift
We will have our sway bars availavlble for sale in about two weeks. They are the first pcs we will be releasing in a full line of suspension products for the Z.
Both our front and rear sway bar are adjustable.
350EVO.......
Old Feb 28, 2003 | 06:09 PM
alex30327's Avatar
alex30327
If they are the same as stock, why buy them? Do they really make a difference? If they do, I might buy them. Does anyone have any conclusive stats?
Old Feb 28, 2003 | 07:48 PM
jran76's Avatar
jran76
Cusco's are solid pieces and are adjustable between 20-37% on the front.
Dwnshift's will be adjustable front and rear both, are solid, and inprove stiffness accordingly (at least as much as the Cusco's if I recall correctly) with fewer bends which should help. The Cusco, Nismo, and stock all seem to have quite a few bends. Dwnshift's will also allow more room for a true dual exhaust, and are already track tested with great results (Dwnshift, correct me if I am wrong).
Old Mar 1, 2003 | 04:04 AM
dwnshift's Avatar
dwnshift
jran76,
Thats correct.
If customers seek an even more agressive bar, we can do that also.
Old Mar 1, 2003 | 09:55 AM
tomsn16's Avatar
tomsn16
Default sway bars
Downshift...the new bar sounds like what I am looking for.
What is the diameter-front?
Are bushings to fit OEM brackets included?
Can you purchase front bar only?
Old Mar 1, 2003 | 02:18 PM
dwnshift's Avatar
dwnshift
The OEM bushings and brackets will work with our bars.
Old Mar 1, 2003 | 07:08 PM
uro279's Avatar
uro279
But wouldn't you recommend new bushings to better match the new bars? Also, does it neutralize the car's handling (decrease understeer)?
Thanks!
Old Mar 2, 2003 | 05:51 AM
dwnshift's Avatar
dwnshift
Our car is very nuetral with a crisp turn in. The ability to go to a softer setting up front might be what autocrossers are looking for since they can only change the front bar (solo rules). With our front bar it gives the user the option of adjustability to tune for differnt conditons.
For track use I recommend getting both bars. We ran our front bar full stiff at Daytona.
New sway bars bushings are not a "needed" item but we do offer delron (super stiff) sway bars bushings for an additional cost.
Old Mar 3, 2003 | 03:24 PM
tomsn16's Avatar
tomsn16
Default Sway Bars
Where is Wright Tuning located in Cincinnati? I will be in Cincinnati this week and might be able to stop by to discuss the new bar.
Old Mar 3, 2003 | 03:33 PM
dwnshift's Avatar
dwnshift
We are on the very far east side of Cincy outside of 275 about 15 minutes off of route 32.
Old Jul 23, 2009 | 05:21 AM
bb1314's Avatar
bb1314
da Terminator!
Reviving an old thread.
The OEM swaybars came out of a NISMO Z, is it the same thing as the aftermarket S-Tune NISMO swaybars? I notice the colors are different with the prior being black and latter being silver.
Old Jul 23, 2009 | 09:36 AM
DavesZ#3's Avatar
DavesZ#3
You could have started a new thread, but I believe you'll fidn the answer here...
https://my350z.com/forum/brakes-and-...-database.html
Old Jul 23, 2009 | 10:05 AM
Gsedan35's Avatar
Gsedan35
No on knows the answer. BUT, since the S-tune shocks and springs are not the same as the Nismo-Z shocks and springs, why would the sway bars be the same? Especially since oem regular Z's built after 04.5 have oem bar's that are almost identical to S-tune bars.
Problem is, with the limited nature of the Nismo Z, unlike regular Z's where oem bar's are a dime a dozen, no one is going to cut a set of bar's in half to measure the hollow wall thickness so we can math out the torsional regidity. Not unless someone can do the math based on weight and outside diameter alone.
Old Jul 23, 2009 | 12:20 PM
bb1314's Avatar
bb1314
da Terminator!
Good call on that. Well I do have 03 OEM regular sway bars sitting around so I can do a weigh comparison. I can also measure the outside diameter. One thing I noticed immediately is the weight difference between the rear OEM nismo swaybar and rear regular swaybar.
Old Jul 23, 2009 | 02:04 PM
DavesZ#3's Avatar
DavesZ#3
I'll do some of the work for you. A simple search of the NISMO sub-forum would have yielded you this thread...
https://my350z.com/forum/nismo-350z/...s-mystery.html
Read through it and you'll find that the front sway is the same as the regular 350Z, the rear is stiffer.
