Can I use ramps when installing sways?
on
I wanted to know if it would be possible to use ramps when lifting the car to install hotchkis sways?
If not how would you all reccomend jacking the Z up so that I can get jack stands under it? The reason I ask this is because I heard its not good to jack one side up at a time because the car could move off of the jack stands.
Thanks in advance
Thanks in advance
on
Thanks for the help guys!
Anybody with Hotchkis have a reccomendation of what settings to put the sway's on?
PS: I have the new model sways that have the collars and the extra adjustment point on one of the bars
Thanks!
Thanks!
on
it is usually recommended to install sways with the suspension loaded so ramps would be just fine.
as for settings to start with - start small and move up. you'll need time to adapt to the handling change of the car, and going all out to start might be asking for trouble.
04-04-2016 07:52 AM
