End Links?
Old Feb 8, 2007 | 10:08 AM
  #221
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no still doing testing
Old Feb 8, 2007 | 10:22 AM
  #222
sfarrah's Avatar
sfarrah
Default SPL end links released
The SPL Parts end links have been released for those of you that are interested.
https://my350z.com/forum/brakes-and-suspension/230829-some-new-spl-stuff-sneak-peak-7.html
Old Feb 8, 2007 | 12:47 PM
  #223
Grommit's Avatar
Grommit
I already ordered the SPL endlinks yesterday. I want to pick up a set of his endlinks as well. You can never have too many endlinks on hand... or something like that.
Old Mar 6, 2007 | 05:39 PM
  #224
Mike Wazowski's Avatar
Mike Wazowski
got my spl endlinks today. great quality and price.
I will also try the Z1 endlinks once they are available.
Old Mar 8, 2007 | 05:16 AM
  #225
reptile718's Avatar
reptile718
Any updates on the Z1 links?
Old Mar 10, 2007 | 04:17 PM
  #226
Scarab440's Avatar
Scarab440
bump for more info!
Old Mar 10, 2007 | 04:27 PM
  #227
Kevins350z's Avatar
Kevins350z
SPL Endlinks FTW!
Old Mar 10, 2007 | 07:19 PM
  #228
Cloud's Avatar
Cloud
Sadly the SPL endlinks did not fix the problem of a loud pop when turning up an incline. I think its the chassis.
Old Mar 11, 2007 | 05:24 AM
  #229
Z1 Performance
Former Sponsor
no news from us yet...been working on some other things as of late, but once we have them ready, we'll post
Old Mar 12, 2007 | 08:36 AM
  #230
daveh's Avatar
daveh
TC's links are still working well for me. Had about 4 track days and 5k street miles on them so far.
Old Mar 14, 2007 | 02:51 PM
  #231
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I'm getting a loud popping noise, too. It's coming from the rear, and I can only think it's the springs or the end links. I've checked the bolts for the sways and don't see anything loose. I can't imagine a chassis actually popping.
Old Mar 14, 2007 | 04:22 PM
  #232
MoodDude's Avatar
MoodDude
To troubleshoot the problem, you are probably going to have to get someone in the passanger seat and see where they hear the sound coming from too. Then when you both agree that the sound is coming from a specific area, have them stand outside the car and see if they still think it is in the same place. Once you have narrowed down the area of the car to a specific spot, jack the car up and start inspecting all the linkages on the suspension, and if it is the rear, don't forget the drive shaft and differential can be the problem.
Sorry, there is no easy solution.
Guys, I haven't posted on here for some time on the Powergrid endlinks, when I have some time, I will get into the specifics about why you can't jugde a book by its cover. What I mean, just because something is big doesn't mean it is strong. You must choose the correct materials for each application, and Powergrid did pick the materials for these to be used on race applications.
When I get some time I will write up a section on material use, and if you need to read some good stuff that will change your way of looking at suspension parts and start asking the right questions - read "Engineering to Win" by Carrol Smith.
Old Mar 14, 2007 | 04:28 PM
  #233
jreiter's Avatar
jreiter
I'm interested to hear your thoughts on the Powergrid endlinks. Namely, why they made the front endlinks so much longer than stock, causing my front sway bars to slightly contact the brake lines. Seems like a design oversight, and I'm considering ditching my Powergrid endlinks because of it.
Old Mar 17, 2007 | 07:58 AM
  #234
Cloud's Avatar
Cloud
not the springs, I had the pop on both my HKS RS springs & stock springs. These were tested with both the HKS shocks and OEM shocks.
Old Mar 17, 2007 | 05:37 PM
  #235
Cloud's Avatar
Cloud
My stock endlinks made no noise at all. However, after installing the SPL endlinks, I feel something in the front suspension shifting or loose. I hear noises when I go over bumps too. What could be wrong?
Old Mar 17, 2007 | 05:38 PM
  #236
Mike Wazowski
didnt tighten them enough
Old Mar 18, 2007 | 10:53 AM
  #237
Cloud's Avatar
Cloud
torque specs?
Old Mar 19, 2007 | 06:31 PM
  #238
Axelerate's Avatar
Axelerate
As tight as humanly possible.
Old Mar 19, 2007 | 06:34 PM
  #239
Mike Wazowski
and check them a few hundred miles later
Old Mar 19, 2007 | 07:00 PM
  #240
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Some things to look out for:
Make sure you tighten the jam nuts for the rod ends
Make sure the endlinks still have plenty of articulation (the spherical bearing can still rotate, and is not binding) after install. You might have to tighten the jam nuts a certain way to ensure this.
If you have older sway bars without collars, you will need collars. The sway bar cannot be allowed to shift left and right, freely articulating endlinks like these will not be able to re-center the sway bar.
