Problem with new brake pads
Old Oct 10, 2006 | 12:06 PM
trusso50's Avatar
trusso50
Default Problem with new brake pads
Folks,
Earlier today I had my front brake pads replaced (kept factory "D1060-AM80B" pads) and the rotors resurfaced (by the dealer).
I just drove it home and noticed a definite difference in the braking performance. Feels more like my old Toyota 4-Runner than the very good braking/gripping that I originally had/loved (old pads were stock, btw).
Since I'm not mechanically inclined, I wanted to run this by you experts before bringing it back to the shop.
Any thoughts as to what could be causing the problem? A friend mentioned that they might have gotten some lubricant on the pads (or something like that), which would wear off in 1-2 days...
Thanks in advance for your help!
Old Oct 10, 2006 | 02:37 PM
StopTech's Avatar
StopTech
Vendor - Former Vendor
Fresh pads and rotors will not have any pad transfer layer to help increase bite in the system. By doing a complete bed-in procedure you can lay down an even transfer layer of the pad material on the rotor surface which will increase bite in the system, similar to how a drag car does a burnout to lay down fresh rubber on the track. The bed in procedure also has the benefit of putting the pads through green fade in a controlled environment instead of in an emergency situation when everything needs to be working optimally.
We have complete bed in instructions on our webste here: http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Oct 10, 2006 | 02:54 PM
Q45tech's Avatar
Q45tech
If you don't do accelerated bed in, it can take 200-400 miles to transfer the brake film properly or improperly.
Old Oct 10, 2006 | 03:08 PM
StopTech's Avatar
StopTech
You will also not put the pads through green fade, which may occur in a panic stop...bad news
Old Oct 10, 2006 | 03:53 PM
trusso50's Avatar
trusso50
Guys - Excellent info and link. Exactly what I needed.
I'll go through the procedure tomorrow.
Thx!!!
Uriyo_
Sep 8, 2021 08:46 AM
