My SPC A-Arm installation
Old Oct 18, 2006 | 08:35 AM
IAPDirect.com's Avatar
IAPDirect.com
Originally Posted by aleok
yay i got mine in today. the look great, but reading the directions and looking at the shims and the bag it come with, i don't know what the hell i'm suppose to do. something about the brake calipers? what am i doing and why? it would be great to see a write up about these shims, becasue idk if i can really figure it out.
The instructions cover this aspect of the installation with a fair amount of detail. SPC also offers great tech support at 800-525-6505. They are very helpful and patient with our customers. Let me know if we can help in any way.
Old Oct 18, 2006 | 04:49 PM
aleok's Avatar
aleok
yea my cars dropped pretty low, probably around 3+ inches. i'm not really sure what and where hub mount is. and what does whicker mean? sorry. thanks
Originally Posted by Gilley
Are you so low, or want so much positive camber, that you need the shims?
The whicker part of the shim should go up top on the hub mount so place the top of the wheel farther out relative to the rest of the suspension.
One guy on G35Driver, Jamaica 2g, apparently put the spacers on his car already. Maybe you can PM him.
Old Oct 18, 2006 | 09:56 PM
aleok's Avatar
aleok
(posted this on g35driver also)
ok i tired installing just the arms. and it's been a disaster. the problem came when i was putting pressure on the rubber ball joint and the thing like "smashed" or "shrunched". but in the pic in the write up the rubber thing held up. is it suppose to smash? then as i'm trying to un-shrunch it the whole rubber thing comes off along with the gold ring that held in on the joint. and all the grease is everywhere. AND the red rubber thing now has a small rip in it. seriously wtf!
the thing shrunched
red thing off and ring off, and rip.
Old Oct 19, 2006 | 06:03 AM
Gilley's Avatar
Gilley
I have no idea what you did. Eek
Will it pop back on? You seem to be having more issued than I did. Pack it with grease and put it back on. Maybe SPC can send you another one.
With a +3 drop, I think you need the shims. You will have to remove the brakes and rotors and then the 4 bolts that fasten the hub to the steering knuckle.
"Whicker" was a mistype of "thicker." The thicker part of the shim goes at the top to where the hub bolts onto the steering knuckle.
Old Oct 19, 2006 | 09:27 AM
IAPDirect.com
Please contact me on this. The balljoint boot will "smush" up depending on the way you have it in. As for it going back on, it will definitely reinstall just fine. PM me if you have any questions.
Old Oct 28, 2006 | 01:29 PM
NISMOFO's Avatar
NISMOFO
I'm having a hard time deciding if I need these because it almost looks like I have a feathering issue in the front (early 2003 model) instead of a camber issue. I might have both though?
Really Dumb Question: So as far as the person doing the alignment...how do they get into the fenderwell to adjust the bolt for the camber?
Old Oct 30, 2006 | 09:22 AM
IAPDirect.com
Is it possible for you to give me a call? I would like to discuss this with you.
888.672.0066
Old Oct 30, 2006 | 10:33 AM
sfarrah's Avatar
sfarrah
Once on an alignment rack you should be able to reach up underneath. At least I know that's how it's done on the SPL's. If you have to take the wheel and spindle off then that's going to take a lot longer.
Old Oct 30, 2006 | 11:05 AM
NISMOFO's Avatar
NISMOFO
That's what I was afraid of.....a very lenghty alignment process. I can't even see the top of that bolt (to adjust) when the car is on the ground...so I'm assuming the car would have to either be raised up or the wheel taken off. But that just means the car will have to resettle again once raised up.
At this point, I'm considering just raising the front of the car up. It's dropped right at 1" right now in the front, but it has extra weight up from the TT setup...it should be dropped 0.56", but like the said...extra weight is bringing it down to 1" of drop.
Old Nov 1, 2006 | 01:01 PM
IAPDirect.com
It is not necessary to take the wheel off to do the alignment. The alignment equipment mounts to the wheel in order to align the vehicle. I have seen vehicles slammed to the ground where the aligment was still performed, this being done as the vehicle is on the alignment rack but raised in the air. Let me know if you have any other questions.
Old Nov 1, 2006 | 04:13 PM
FrickU's Avatar
FrickU
Good write up.
Old Dec 13, 2006 | 06:59 PM
bleunetizen's Avatar
bleunetizen
but do you have enough space to adjust the adjustable A arm without taking the wheel off?
Old Dec 14, 2006 | 03:59 AM
aleok's Avatar
aleok
^ probably not since, your car is dropped. i didn't have enough room.
Old Dec 14, 2006 | 06:25 AM
Gilley's Avatar
Gilley
My alignment guy didn't have to take the wheels off to adjust the a-arm. I guess he did it in the air and lowered it to check it. I didn't see him.
Old Dec 22, 2006 | 03:37 PM
bleunetizen
Before alignment:
Camber: LF -0.3 RF -0.4 LR -1.8 RR -1.7
Toe: LF -0.09 RF -0.07 LR -0.47 RR +0.55
After alignment:
Camber: LF -0.4 RF -0.4 LR -1.3 RR -1.3
Toe: LF +0.05 RF +0.05 LR +0.10 RR +0.09
theres no change in the front camber.
I don't think your alignment guy even touched the new A arm becuz it was in spec before alignment anyway.
Old Dec 22, 2006 | 04:29 PM
chrisjennings's Avatar
chrisjennings
Where did you get the front rotors and caliper brackets?
Old Dec 23, 2006 | 05:16 AM
Gilley's Avatar
Gilley
Can you believe that my buddy and I eyeballed the alignmant in the garage? I was surprised we were so close.
I got the rotors and caliper brackets from a friend who had them made by Fast Brakes. It was a one off deal that I think they were devoloping but got little interest. They work awesome and are each 6.5 pounds lighter than the OEM Brembos.
Old Jan 9, 2007 | 05:38 PM
  #38
JKC350z's Avatar
JKC350z
if im just planning on installing the a-arms onto a 350z that has been lowered with tananbe gf210's....will i need to remove the strut and spring assembly?...or can the a-arm just be removed and switched out?
Old Jan 16, 2007 | 12:09 AM
  #39
JKC350z's Avatar
JKC350z
anyone?
Old Jan 16, 2007 | 12:21 AM
  #40
JDMFairladyZ33's Avatar
JDMFairladyZ33
No doesn't look like you have to remove anything. The A arm sits independent of the strut assembly. Look at Gilley's install. He never touched the struts/springs. He did have to loosen it to work around it but the strut assembly (w/ springs) stays intact.
