changed pads, now car pulls right!
Old Oct 22, 2006 | 02:42 AM
jsupetran's Avatar
jsupetran
Angry changed pads, now car pulls right!
So I changed my brake pads, cool no squeeks but when I drive on the road or the freeway, when I let go of the wheel, the car pulls to the right ever so slightly. Now, sometimes the road is uneven, but I know my car and it never did this before prior to the brake pad job.
Any clues or suggestions would truly be appreciated.
Old Oct 22, 2006 | 05:40 AM
Kolia's Avatar
Kolia
Originally Posted by E***zzzzy
Did u surface the rotors?? Or even sandpaper them ????? If not u should have ----Just putting on a new set of pads is like just installing 3 sparkplugs. Ur old Pads/rotors worked as a team, maybe a poor one but none the less there was an understanding between the two. A good brake job demands that the two partys coexist.
Two other factors can cause that also----1. air in one side---Did u crack ur bleeders when u got done ? 2. A bad flexable brake line. There again, NEVER just replace the bad one ---replace both.
No no no no. Don't turn or sand your rotors. Just do a proper bed-in.
To the OP. Does the car pull right all the time or just under breaking ?
If it's always, it's not related to the brakes. Probably in your head. Check tire pressure, have the car aligned if necessary.
If it's under breaking, make sure your bed-in in done properly, give the pads some time to wear in place. Did you bleed the brakes? Are the bleed valves thight?
Old Oct 22, 2006 | 05:58 AM
Kolia's Avatar
Kolia
Something weird happened in between postings... lol
Old Oct 22, 2006 | 05:13 PM
jsupetran's Avatar
jsupetran
No it doesn't pull under braking. Its not like I am struggling keeping the car straight (which I am not) but when I go straight and let go of the wheel, it is apparent I am pulling right. It never did this before. Hmm, I'll check the tire pressure. Thanks for the replies guys, and what happened to the first response to my post cause it disappeared! I didn't bleed the brakes since the valve was never open so air did not go in, but what does "crack the brakes mean"?
Old Oct 22, 2006 | 05:25 PM
thirty5ounces's Avatar
thirty5ounces
its in your head....
Old Oct 22, 2006 | 05:31 PM
Eazzy's Avatar
Eazzy
Cracking a bleeder is an expression--It means just open it a little to release the air ----Dosent matter if u dont open the line --Always open a bleeder a little to release the bubbles after installing pads--there will almost always be a little air pressent --Just a good habit, U dont have to bleed them, just open it and tap the caliper to loosen any air clinging to the interior. Gravity will be enough to purge it.
And if it dosent flow fluid--u prob have a bad flex line
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
RWDBajan
Sep 17, 2015 04:52 PM
Bigsyke
Sep 11, 2015 06:19 PM
