OK, So who has installed the SPC Camber Shims? w/out ABS, VDC, SLIP light coming on?
Old Oct 28, 2006 | 03:53 PM
aleok's Avatar
aleok
Default OK, So who has installed the SPC Camber Shims? w/out ABS, VDC, SLIP light coming on?
after installing the shim my ABS, VDC, SLIP light all came on. i'm sure i didn't break the sensors, i was very careful. i'm sure i followed directions, and i've tried readjustings twice already. anyone can help?
Old Oct 29, 2006 | 02:30 AM
aleok's Avatar
aleok
heres some pics of what my sensors look like.
drivers side
passengers side
Old Oct 29, 2006 | 06:30 PM
aleok's Avatar
aleok
anyone? are my sensors correct?
Old Nov 13, 2006 | 02:26 AM
zachhindes's Avatar
zachhindes
Default same problem
hello, i just recently installed the same kit with the spc upper control arms also,i am having the same problem withthe lights. if you have any question just ask, or if you knowhow to fix the problem please let me know, would be mucn appreciated, thanks zach
Old Nov 13, 2006 | 05:39 PM
axolotol81's Avatar
axolotol81
I installed my shims the other day, but my problem was over torqueing the hub bolts. My dust cover was rubbing against my rotor not allowing it to spin freely. No lights for me though. Did you maybe bend that ABS bracket while tightening the bolts? I noticed that little piece seems pretty flimsy and can be bent easily.
Old Nov 18, 2006 | 06:32 AM
zachhindes's Avatar
zachhindes
Default figured it out
hey guys, i finally got sick of messing with my abs sensor, so i called spc performance talked to the tech dept. and all i did wrong was overtighten the 13mm nut on the bracket that they provide and it bent the bracket and was to close to the abs. my brackets must have gotten bent from overtighting them so i had to bend the back, but the guy from spc said he would send me new ones, if anybody has any question feel free to ask. zach
Old Aug 18, 2007 | 03:02 PM
Don-TireGuy's Avatar
Don-TireGuy
Did you ever get this fixed?
Old Jun 28, 2008 | 03:26 AM
Spoiled Z's Avatar
Spoiled Z
I installed the SPC shims yesterday and I'm having the same problem the ABS, VDC and SLIP lights are on.
Old Jul 3, 2008 | 06:54 PM
DogZilla's Avatar
DogZilla
As am I. The installer did everything correctly, yet no matter what the lights have come on, and stayed on. Now my dash looks like the warning light panel of a Russian nuclear power plant.
Anyone have an easy, and permanent solution???
Old Jul 4, 2008 | 05:11 AM
zzz350's Avatar
zzz350
I was all set to order those front control arms until I read this thread, now you guys have me a little nervous (note: very pleased with the SPC rear camber kit).
Old Jul 4, 2008 | 05:14 AM
DogZilla's Avatar
DogZilla
If I would have known before ordering, I wouldn't have. I'd have spent the money, and gotten the SPL's.
Old Jul 4, 2008 | 06:46 AM
laze1's Avatar
laze1
Questions:
Do the shims/spacers go between the wheel bearing-hub assembly and the aluminum suspension upright?
If so:
Do they add Positive camber?
If so, can they be turned upside-down and used to add negative camber? (without using the upper-A arms)
Old Jul 4, 2008 | 07:48 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I just installed the SPC upper control arms without installing the shims.
The shims allow you to have more positive camber. I am dropped on Tein S techs and my camber isn't so bad that I needed the shims.
Old Jul 27, 2008 | 04:46 AM
laze1's Avatar
laze1
anybody have a picture of the SPC camber shims? "not installed just loose"
(I did try the SPC web site, pics no good there)
I am still wondering if it can be installed upside-down to give more negative camber
Old Jul 27, 2008 | 07:27 AM
carbon z's Avatar
carbon z
I don't know if this is the answer. ABS sensors need to have a minimum clearance to read the groves on your brake rotor. Usually when a sensor is removed, to set that clearance, push in on the sensor till it seats against the rotor. To make sure it is seated correctly, spin the rotor a couple of turns to allow for rotor run out. I am not a Nissan mechanic, but I have set up the ABS systems on big trucks. I know that the systems are technically the same.
Old Jul 27, 2008 | 09:05 AM
moforeynolds's Avatar
moforeynolds
My install yielded the same problems, my dash was lit up with all the idiot lights (and my ABS kicking in on occassion). I was going to head back to the shop to have them space the sensor correctly, but for whatever reason it kind of worked itself out and I no longer have any problems. Weird.
Old Aug 1, 2008 | 02:39 PM
THE_SCHROED's Avatar
THE_SCHROED
Now I'm having this problem. I wonder if I just take out the shims will it fix it.
Old Aug 1, 2008 | 02:42 PM
DogZilla's Avatar
DogZilla
When mine were installed, the installers had no idea why the spacers were needed, and thought they may have started the problem.
All I know is, it's a severe design flaw on SPC's part.
Old Aug 1, 2008 | 02:46 PM
THE_SCHROED
Are you not running the spacers?
Old Aug 1, 2008 | 02:49 PM
DogZilla's Avatar
DogZilla
I am. The installer said the instructions called for them, so he added them. He also added he didn't think they needed them, and the install would have been fine without them.
All I know is a sensor ended up going bad, and subsequently the ABS control unit, although it may have easily been a coincidence.
