JIC or HKS
Old Nov 7, 2006 | 08:32 PM
Drift_corners's Avatar
Drift_corners
Default JIC or HKS
I got my mind off Tein Flex now, iv shifted to HKS hypermax RS. And JIC Fla-2. What would you recomend for spirtited street driving, alot of autocross, and some track in the future. I eventualy want to track alot. Comfort is a non issue. any sugenstions.
Old Nov 8, 2006 | 01:16 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
either would work fine quite honestly
Old Nov 8, 2006 | 01:29 PM
IndustrialDuane's Avatar
IndustrialDuane
JIC is what im getting when i get the funds!
Old Nov 8, 2006 | 01:53 PM
THE TECH's Avatar
THE TECH
I like both. You can't really go wrong with those choices. Although I think the only thing that the HKS has over the JIC is that HKS USA can rebuild them if you have a prob whereas I don't think JIC has any facility to do this here in the states.
Old Nov 8, 2006 | 05:26 PM
adrianko43's Avatar
adrianko43
JIC is located in Downey, CA and they can rebuild your shocks for you. I just bought the A2's a recently, and the handling is awesome, and the ride is really stiff even on full soft, but no complaints here. With the HKS, there is more range between full soft and full stiff.
Old Nov 8, 2006 | 05:32 PM
Drift_corners
is it overkill for street as in will my handling be worse on the street.
Old Nov 8, 2006 | 06:17 PM
Drift_corners
I will use the car on the street 90% of the time, i want performance though, i could care less about comfort.
Old Nov 8, 2006 | 06:29 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Looking for HKS RS
I am on the same boat, I am wondering who has the best prices on the HKS for the 350Z.
THX
CESAR
Old Nov 8, 2006 | 06:31 PM
Drift_corners
i think im going with the JIC unless someone tells me its not streetable, but hks if you can find it for like 1800 its a good price i found JIC for 1950
Old Nov 8, 2006 | 07:07 PM
Axelerate's Avatar
Axelerate
I have the RS's and use them for the exact purposes you describe.
Mostly for the street, occasional auto-x and more importantly I track it about
4-5 weekends a year. The street comfort is great, especially at high cruising speeds and even on stiffer settings it's very livable. It feels like stock ride quality but with firmer dampening.
The track abilities are also very good for a streetable coilover, no issues at all and would purchase them again if I had to.
I also did my research before buying and to me it seemed that HKS actually did some real world testing with them before releasing them and I think it paid off. They marketed it as a US spec coilover due to our rougher roads and I also liked their spring rates. Also, very easy to adjust and the parts still look great when changing wheels.
Old Nov 8, 2006 | 07:09 PM
Drift_corners
do you think i will find the JIC streetable im leaning towards it for all out performance
Old Nov 8, 2006 | 07:20 PM
first350's Avatar
first350
I have the JIC's and think they're completley streetable - I have them set 2-3 clicks from full soft for the street and don't have any problems...I'm also lowered around 2.5" which has given me a good amount of negative camber (I'm in the process of getting camber arms) - at the beginning, the car felt a bit twitchy, but after a few weeks it feels normal to me. I ended up drilling 2 really small holes in the rear strut (only through the metal, not plastic) so that I could adjust the dampening.
I've done a few autoX's and they've performed well.
*There is more noise with these, but from what I've read, just about all coilovers are going to be noisier than OE.
-Peter
Old Nov 8, 2006 | 07:24 PM
Axelerate's Avatar
Axelerate
From what JIC owners have told me they are pretty stiff. There springs rates are stiffer almost by 200 lbs in the back. I really like my equal spring rates of 8k front and rear. That way I can dial out any over/under steer usally by tire pressures and then with damper settings if I need to. I doubt you'll be disapointed with either choice, but after comparing both I feel that the HKS are a better deal and better designed coilover with my driving in mind.
I'm not a JIC fan mostly becuase of their poor customer service I know they had in the past, but they might of fixed them. Not sure. I have also heard z owners with JIC's talk badly about them at the track and mostly complaing of poor valving with the struts.
As for price, Z1 has a very good one, plus they are close to you.
http://www.z1auto.com/prodmore.asp?m...ing&prodid=301
Spent some $$$ with them, and always have great service.
Old Nov 9, 2006 | 12:09 AM
adrianko43's Avatar
adrianko43
If you dont care about comfort, then JICs are the way to go. Although they could be overkill if used just for the street. For street though, i think that the difference in handling between the HKS and JIC would be hard to differentiate.
Old Nov 9, 2006 | 08:24 AM
Drift_corners
yeah ill probly go with the JIC once i graduate and get some more $ in my bank i plan to track the car alot, i dont want to have to switch to something diffrent in a few years.
gonzalo_300zx
Dec 18, 2015 04:14 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
