Question 350Z and G35 Coupe - Same Shock?
Old Nov 10, 2006 | 06:58 PM
BJF2K's Avatar
BJF2K
Default Question 350Z and G35 Coupe - Same Shock?
Are the 350Z and G35 Coupe OEM shocks the same?
Old Nov 10, 2006 | 08:36 PM
Gsedan35's Avatar
Gsedan35
I have no idea what your motive is in asking the question, but to me, answering it deserves more then a one sentance because of differances in each car over the years.
2003-2004 350Z
314/342 spring rates
vs
2003-2006 G35 coupe with oem 17" or 18" wheels
Z shocks are totally different with a whole lot more compression dampning and not enough rebound control. Known for excessive bounce and porposing, they don't behave any better when used on a G35. Buy D-specs or Koni sports.
2004.5-2006 350z (revised suspension)
314/427 spring rates
vs
2005-2006 G35 coupe with oem 19" wheels
The shocks between the two cars and not the same, at least not by part numbers. They are closer in valving, though I would not argue with anyone that said in back to back drives they feel the same.
In either case, both oem Z setups have shock valving that is stiffer then any G coupe with oem 17 or 18 inch wheels.
_koubie_
Sep 20, 2015 06:34 PM
hardkicks
Sep 20, 2015 12:28 PM
