Some new SPL stuff sneak peak
Old Feb 27, 2007 | 04:23 PM
  #161
Kevins350z's Avatar
Kevins350z
just ordered mine today. wonder when i will get them..
Old Mar 6, 2007 | 05:36 PM
  #162
Mike Wazowski's Avatar
Mike Wazowski
got mine today. look great, thanks
Old Mar 23, 2007 | 11:28 PM
  #163
axolotol81's Avatar
axolotol81
Just out of curiousity, where do those 2 extra spacers go on the front end links? I'm gonna install mine tomorrow and want to make sure where they go properly. Thanks. And the end links look great, can't wait to test them out.
Old Mar 24, 2007 | 08:45 AM
  #164
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
If you look at the following picture:
There is a big cone spacer on the endlink on the bottom where it connects to the lower arm. The additional ring spacer can be added (it should be added in the following order: endlink ball joint, ring spacer, cone spacer, lower arm), or the cone spacer can be removed and just the small spacer installed (ie. endlink ball joint, ring spacer, lower arm). to allow the endlink to reach a more inward or outward adjustment hole on the sway bar without binding.
So to summarize, there are 3 possible configurations:
endlink ball joint, ring spacer, cone spacer, lower arm -- furthest position towards back of car
endlink ball joint, cone spacer, lower arm -- middle position
endlink ball joint, ring spacer, lower arm -- position closest to front of car
You want the installed endlink to still allow some amount of pivoting movement when the suspension moves up and down under travel (try visualizing it). Make sure the bearings are not already binding or close to binding after everything is tightened down. That is the most common mistake when installing spherical bearing endlinks.
If you are unsure of your installation, take a picture and email it to us at sales@splparts.com, and we can tell you if everything is installed correctly.
Old Mar 24, 2007 | 03:27 PM
  #165
axolotol81's Avatar
axolotol81
Cool. Thanks for the info. Now it all makes sense. Thanks again.
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pdexta
Sep 14, 2015 11:27 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
