Carbotech brake pad update #3, the final chapter
Alrighty, so all the parts are due in tomorrow. We'll have all materials necessary to make front AND rear brake pads for both the track and standard models in any of our street or competition brake compounds. Contact info is located in my sig.
I appreciate everyone's patience.
Matt
Matt
Sounds cool!
I just replaced my rear pads with stocks, but maybe I can get some track pads to swap in for the occasional track day. I'll have to think about this.
Thanks for the info!
-D'oh!
-D'oh!
I posted this on another thread but here goes just in case you don't see it there:
Matt, are you guys working on a track pad for the rears and fronts for that matter? I mean strictly track.
I went out the track and my stock rears were toast but a friend of mine had the bocats in back and the Hawk + in front and they got toasted as well as his rotors.
Any of the Carbotech Panther pads are great track pads. I'd say some Panther Plus or Panther XPs is what you'll need. Both of these will destroy Hawk HP+ pads in braking, feel, bite, and fade resistance. Actually nither of these I'd personal run on the street except to get to or from a track. These are my deductions from owning all 3 of the above listed pads as well as several other pads from Carbotech and other brands (Porterfield, Axxis, and others). I've bought nothing else but Carbotech pads over the past 2-3 years and I don't think I'll ever switch.
We have SERIOUS track compounds and we can put those serious compounds on any backing plate. And since we have all the 350Z plates.....
Was that Rick? Yeah, I made the mistake of not giving him an aggressive enough material. I guess I figured a car that new and expensive, the owner wouldn't be going out there and driving 10/10ths. My mistake. I believe I sold Rick Panther Plus for the front and they didn't work out for him at Sebring-long course. I recommended that compound for him because it is our most streetable track compound and generally perfect for HPDE/lapping day. I should have gone with Panther XP. When he calls back, we're getting serious with his brake selection
Yes that was Rick, and those pads looked like they had a meltdown. And in Rick's defense I don't know how you can't go all out with this car it just begs to be driven.
Whe you come up with a combination let me know as I would be interested as well, I want a track dedicated pad, I might even go with track rotors also. I had some Axis Ultimates and they fared OK but I think it was because I didn't go at it hard until the second day and I think I am going to reinstall my stocks as they do not sound so good I think the surface of the pads got coocked.
Autox is not as hard on the pads as they do not get as hot, but autox pads just don't cut it on a track, specially Sebring where you have basically 3 stretches where you get going before slamming the brakes on, it was fun though.
Hey Matt went to little Taladaga last weekend and the panthers did fine on the front but we got to have some rear pads.
By the time we got done last Saturday I completely distroyed the rear pads and had to drive the car on metal to metal rear brakes
all the way back to Nashville
So...yes, we have better race compounds available. At the time, I didn't think to recommend that to the driver of a brand new $30K car doing a driving school.
Trying to read between the lines, do we ned to find a way to get better cooling to the brakes? Or are suggesting that a big brake upgrade is needed like a Stoptech, which I was actually considering for the fronts.
But I'd start with getting more air to the brakes. That's cheap. Always evaluate the least expensive option first, it might save you a couple grand.
Data point: The pads I sold Doug were the same pads I sold Rick: Panther Plus. Same car, same pads, different track, no problems. That illustrates the variation in braking requirements you'll see from track to track. P+ just wasn't enough for Rick at Sebring.
Okay, now i have a quick question..... I just bought the P+ front/ bobcat rear for my track model Z. I am heading to Mid-Ohio in 2 weeks. Did i order the wrong pads??? I drive extremely hard as i am extremely competitive... I hope i won't be wishing that i got the XP's...
Quick,
I'm curious how these pads hold up under HEAVY track conditions. I have the same pad setup for my Brembos, that are still in the box. They have to be sent back to Matt for a rework, too tight of a fit.
Are you running with the stock brake fluid and lines ?
Good luck at Mid-Ohio.
well, currently everything is stock. The pads are still in the box. I haven't even trie d to put them on yet. If i need a heavier grade pad though, i want to send them back so i can get the replacements before my race!
I would suggest changing the fluid, I used ATE Super Blue.
I ran at little Talladega Gran Prix , which is a mile and 1\4 flat "U" shaped track for 5 sessions at 5 to 6 laps each session. In the back and front straights I was hitting between 80 to 90 mph . My stock brembos held up great. The only upgrades were to the brake lines and fluid. Needless to say I was impressed.
But I'm always looking to improve the setup over stock....hence Carbotech
Matt, thanks for the quick order. I recieved the bobcat pads for my rear Performance/Touring brakes today. I will be going to the New Bern AutoX on Sunday and will put them and the Panther+ on my fronts to good use. See you at VIR next week.
