Weird noise.
Old Dec 28, 2006 | 11:29 PM
plumpzz's Avatar
plumpzz
Default Weird noise.
When i hit a big bump, i hear a very loud... noise coming from the back of the car. Sounds like a very loud creak... like how an old mattress sounds when somene jumps on it, but pretty loud.
My car only has 20k miles on it, so if its a suspension issue, i would want to get it checked out.
I have a sway bar + 10'' wheels in the rear, but the wheels are lighter than stock. I never got to preload the sway bars so that could be it. let me know what you guys think it is.
Old Dec 29, 2006 | 12:48 AM
NissanZfan's Avatar
NissanZfan
I say go to the dealership, you sit in the passenger seat while the tech drives the car.
Old Dec 29, 2006 | 01:27 AM
Mark Basford's Avatar
Mark Basford
Have you seen the thread with the cracked rear subframe......
Old Dec 29, 2006 | 05:06 AM
z-u-later's Avatar
z-u-later
More than likely, it's either your sway bar or the end links. Do you have an adjustable after-market sway bar? If you do, you may want to adjust the setting to see if the noise goes away. Also, check the end links to see if there's any play on the bushings.
Old Dec 29, 2006 | 05:37 AM
RBALDINELLII's Avatar
RBALDINELLII
I have the same thing and have had it ever since I installed the after market exhaust. It's real close to the hotchkis sway bars. It seems to do it more when its cold outside.
Old Dec 29, 2006 | 12:22 PM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
souds like the exhaust is slapping the under carriage like A ******* slaps the A$$ Of A Hooker. or maybe its something else... I just like that analogy.
Old Dec 29, 2006 | 12:28 PM
MR_X's Avatar
MR_X
check to see if the sawy bar bushings have grease on them.
Old Jan 3, 2007 | 06:44 AM
plumpzz's Avatar
plumpzz
Its not the exhaust slapping. Its a creaking noise, not a metal to metal noise. I think it may be the endlink. I have to get it up to see, but its too cold outside.
Old Jan 3, 2007 | 07:48 AM
wren57's Avatar
wren57
+1 on getting all your suspension parts/bushings greased up. I had a horrible creaking noise start on my way home from a road trip (3hrs from home, mind you) and almost had my car towed home because of it... it was CONSTANT coming from the front, I thought the car was about to fall apart. Well, I risked it, and got everything lubed up when I got home and the problem was gone.
Old Jan 3, 2007 | 07:57 AM
plumpzz's Avatar
plumpzz
okay ill let the dealership know. They grease everything for me normally..except for swaybars. Where can i get teh swaybar grease for stock rubber bushings??
Old Jan 14, 2007 | 07:15 PM
mistico's Avatar
mistico
Did the rease fix the issue?
I have the same noise on my 06 and have hotchkis sways. They've only been on for a few months though and already the sound. I hope it's just grease.
The good thing about the sound? It takes my mind away from all the other sounds the Z has . Brand new car and it has more noises/sounds coming from everywhere han anything else I've driven. it sounds like a 30 year old car inside!
Old Jan 15, 2007 | 02:20 PM
plumpzz's Avatar
plumpzz
i havnt been able to do anything. I just got knee surgery.
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
PureR3d
Sep 10, 2015 06:23 PM
