Squeaking...new rotors with brakes?
Old Jan 8, 2007 | 11:05 AM
md350's Avatar
md350
Default Squeaking...new rotors with brakes?
I bought my Z, used, about a month ago now. The front brakes have been really squeaky. I had Nissan check them during service and they are at 30%. I've never bedded-in brakes before but started reading about it since I joined these forums...to do that...should I go with new rotors as well when I get new brake pads because of the leftover material on the rotors? Or turn them?
Bottom line, I don't want super squeaky brakes on Z. Its really noticable...loud and frequent.
Old Jan 8, 2007 | 02:50 PM
Depends what is squeaking. When you replace pads, the caliper should be lubed with caliper grease. It prevents the pad-caliper from squeaking.
If its the pad to rotor, then replace the pads. I recommend turning the rotors when replacing pads.
Old Jan 8, 2007 | 02:53 PM
my2004Z's Avatar
my2004Z
Originally Posted by davidv
Depends what is squeaking. When you replace pads, the caliper shroud be lubed wit caliper grease. It prevents the pad-caliper from squeaking.
The extra material on the rotor ends up hitting the edge of the pad thus causing it to squeak. This fairly normal as most performance cars have rotors that are somewhat soft to allow for better braking. Turn the rotors when you get the new pads and make sure that the pads are spec'd for the Z if you have stock rotors.
Old Nov 16, 2007 | 07:12 AM
VO...'s Avatar
VO...
Administrator
Default Having similar Problem
I recently installed Stoptech 2 Pot 13inch rears with Axxis Ultimate pads. I completed the bedding process with 2 cycles, 10 stops per cycle with 10mins cooling period between cycles. The rear brakes squeal when I'm about to come to a complete stop and I'm barely applying pressure to the brake pedal.
I tried bedding the brakes again by performing 1 more cycle of 10 stops, but it has not helped. I suppose I could try some anti-squeal gel on the back of the pads, but frankly I don't see why I should have to do this. I am running the exact same set up in the front, only with 4 Pots, and have had no problems.
Anyone have any suggestions?
Old Nov 16, 2007 | 08:45 AM
md350's Avatar
md350
Wow old post. I don't squeak anymore...don't know what I did though. All 4 pads are relatively new now, but I didn't change the kind of pad.
Problem was mostly with light pressure like you are describing though.
Old Nov 16, 2007 | 08:49 AM
VO...'s Avatar
VO...
Administrator
I'm hoping it goes away. I called the Stoptech tech line and left a voicemail. I'm waiting to hear back from them. I really don't feel like removing the pads to put the gel chit on them.
Wow old post.
I'm the type of guy that likes to search to find my topic, then add on to it instead of starting a new thread.
Old Nov 16, 2007 | 12:00 PM
VO...'s Avatar
VO...
Administrator
Default Found the answer
Pat from Stoptech called me back. We discussed the problem and he suggested I "Chamfer" the brake pads. This should alleviate any brake squeal.
VO(goes out and find answers to his questions 99% of the time)
Old Nov 19, 2007 | 07:13 AM
VO...'s Avatar
VO...
Administrator
Default Update...
I tackled the job on Sunday evening. Total time including removing and reinstallation was only a couple hours. One thing I didn't notice when I had originally installed the Axxis UTL's is that they were already chamfered. Since I had already had the car lifted and wheels removed I figured I's chamfer the pads some more. In the pics below you can see the original condition the pads come in. The last pic is of the grinding wheel I used to remove the bulk of the pad material. I then used a steel file to even out the entire side.
Attached Thumbnails Squeaking...new rotors with brakes?-imgp3232.jpg   Squeaking...new rotors with brakes?-imgp3235.jpg   Squeaking...new rotors with brakes?-imgp3236.jpg
Old Nov 19, 2007 | 07:15 AM
VO...'s Avatar
VO...
Administrator
Here are pics of what the pads looked like after I made the leading and trailing edges identical..
The last pic is a comparison of the pads in orginal state vs. grinded down state..
Attached Thumbnails Squeaking...new rotors with brakes?-imgp3239.jpg   Squeaking...new rotors with brakes?-imgp3240.jpg   Squeaking...new rotors with brakes?-imgp3241.jpg   Squeaking...new rotors with brakes?-imgp3237.jpg
Old Nov 19, 2007 | 07:23 AM
VO...'s Avatar
VO...
Administrator
Final conclusion, while this may work on some applications, it did not work for me. After a long discussion with Pat @ Stoptech tech support, we decided that I would have to go with a less aggressive quieter rear pad. Reason being is because I don't drive the vehicle enough to ensure that the pads will ever get "broken in". It's a show vehicle that only recieves about 30 miles per month. Pat advised that I would have to drive the vehicle several hundred miles before the Axxis pads actual break in and the noise stop.
Just an FYI, the back side of the pads already have a sound dampening material attached.
Old Nov 27, 2007 | 08:09 AM
VO...'s Avatar
VO...
Administrator
Default Update...
This past weekend I took the rear Axxis UTL's off and tried my hand at making them quiet again.
This time I picked up some CRC Disc Brake Quiet at Autozone. It's roughly about $4.00 per bottle.
Here's their website:
http://www.crcindustries.com.au/cata...t?openDocument
I removed the noise supressing tape that the factory sticks on the back of the pads. It obviously doesn't work. After this, I applied a nice thick coat of this stuff directly to the metal backside of the pad, then let it sit all night to cure. You only have to let it sit for 10mins or so, but I had somewhere to go.
The next day it was dry, but extremely tacky, sticking to everything. In order to slide it back into the caliper without getting this gooey stuff everywhere, I pushed the pistons in a little bit with a C-clamp. This gave me enough clearance to slide the pads back in without dislodging any of the tacky gel.
Took it for a test spin last night. I still squeaks every now and then, but nothing as bad as previous. Personally, I'm a perfectionist and even the slightest squeal is not going to go well with me so I'm going to end up replacing the pads with another brand. Posi Quiet 104's will probably be my choice. Just thought I'd share this info with the community since my search only turned up 2 thread that had to do with brake pad squeal.
Old Jan 10, 2008 | 11:58 AM
VO...'s Avatar
VO...
Administrator
Default New Pads
I finally ordered new rear pads. I decided on Posi Quiet 104's at the advice of Stop Tech tech support. They came in today. I'm going to try and get them installed tonight, then test drive it if it's not raining. I attached a few pics so you guys can see what they look like. Posi Quiet pads are suppose to be performance pads that are close to OEM design, hence eliminating squeal. You can even see they come with a brake shim attached already. No need for the gooey coating. I'll post results when I get to test drive it.
Attached Thumbnails Squeaking...new rotors with brakes?-imgp3386.jpg   Squeaking...new rotors with brakes?-imgp3387.jpg   Squeaking...new rotors with brakes?-imgp3388.jpg   Squeaking...new rotors with brakes?-imgp3389.jpg
Old Jan 10, 2008 | 12:06 PM
Clipdin's Avatar
Clipdin
SHIFT_happens
Subscribing.
Old Jan 10, 2008 | 12:11 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by Clipdin
Subscribing.
Man, I tell ya... I've put alot of time and effort into ressolving this brake squeal ordeal. I sure hope this works. The squealing on my current pads is so bad. It's embarrassing everytime I pull into a parking lot or stop at a light.
Old Jan 10, 2008 | 12:28 PM
md350's Avatar
md350
Yeah you've put a lot of effort into it. Will be interesting to see the difference with the shims on there this time.
Old Jan 10, 2008 | 12:40 PM
VO...'s Avatar
VO...
Administrator
I'm figuring that will be the key to stopping the squeal....
*fingers crossed
Old Jan 11, 2008 | 06:44 AM
VO...'s Avatar
VO...
Administrator
Default New Brake Pad (Posi Quiet 104).....
I managed to set aside some time last night to change out the rear pads.
It was a good night to work on the car. A clear cloudless night, around 58 degrees outside. Before starting the work, i had to get the setting right. Stevie Ray Vaughn and a few bottles of Heinekin....
Attached Thumbnails Squeaking...new rotors with brakes?-imgp3390.jpg   Squeaking...new rotors with brakes?-imgp3393.jpg
Old Jan 11, 2008 | 06:48 AM
VO...'s Avatar
VO...
Administrator
After the wheels were removed, I proceeded to remove the old Axxis UTL's I was previously using. The red gooey coating I placed on the back of the pads made it pretty hard pulling them out because the stuff acts like glue and pretty much glued the pads to the pistons. With a little persistance I was able to pry them free. You can see the caked up stuff left over on the pistons. Surprisingly, I was able to remove it with a little finger rubbing, a small screwdriver, and small needle nose pliers...
Old Jan 11, 2008 | 06:51 AM
VO...'s Avatar
VO...
Administrator
Next went the new pad install. I had already pryed the pistons back some ways with a flathead screwdriver, wedging it between the old pad and rotor. It was enough to pull the old pads out, but not enough to install the new pads. No problem, I used the trusty old C-clamp to recess the piston futher back into the caliper. A towel placed on the end of the C-clamp kept any paint on the caliper from being damaged....
Old Jan 11, 2008 | 06:59 AM
VO...'s Avatar
VO...
Administrator
Last step was the new pad install. This didn't go so smooth. I've included a close-up pic of the backside of the Posi Quiet pad. In the pic you can see the shim does not exactly have the same size hole as the pad itself. This proved to be a pain in the **** when trying to push the Stoptech thru-pins in place. What was happening was the pin would snag on the lip of the shim, making it difficult to push through the pad. The first pad took me awhile to get the pin through. The shim actually belt back off the pad a little because I kept trying to force the pin through, but it kept snagging on the shim. I finally got it through by using a tap on the end of the thru pin and hitting it with a light hammer.
When installing the next set of pads, I used a phillups screwdriver to wedge into the pad hole. With the screwdriver in the hole, I worked it in a cirrcular motion to bend the shim back a hair. It wasn't visibly much, but enough to allow the thru pin to slide through easier...
