SPC camber + toe kit Issues!
Old Jan 25, 2007 | 12:58 PM
sk26dett's Avatar
sk26dett
Default SPC camber + toe kit Issues!
Has anyone else had problems with their SPC camber kits. I dropped my car on Eibach sportlines, and the rear camber was way off so i got an SPC kit installed as well. when i took my car to an alignment shop they still couldnt get my toe angles right? did the shop install them wrong?
Old Jan 25, 2007 | 01:41 PM
redlude97's Avatar
redlude97
Did the shop elongate the hole or just install the new toe bolt? Most likely an install issue or the alignment shops lack of skills, the Toe bolts can fix huge toe variations, it doubles to triples the range of the stock bolts
Old Jan 26, 2007 | 01:25 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
your shop did not install them properly (or at all)
Old Feb 1, 2007 | 05:04 AM
Axelerate's Avatar
Axelerate
Either that, or the insides of your tires are long gone causing it to mess up the camber/toe.
Old Feb 1, 2007 | 09:26 AM
abui01's Avatar
abui01
Had that happen the first time I got my mechanic to align my rear wheels, he couldn't get the right rear to align properly... later he found out that there are TWO toe bolts that can be adjusted, LOL.
The arm that SPC gave you came with a new toe bolt, but that's not the ONLY toe bolt that can be adjusted, there's another one!
Old Feb 1, 2007 | 09:37 AM
abui01's Avatar
abui01
Actually, I did have an issue w/ my SPC camber arms as well: They are not holding their camber/toe specs. I installed them back in Oct. and the camber/toe got worse overtime even when everything was tightened down. I went to get an alignment and they brought everything back to spec. 3 months later I went back to the shop since I was feeling some *bump steer* and we put it back on the alignment rack... and AGAIN: Camber/Toe were WAY off.... only after 3 months? I know I'm probably one of the most careful drivers out there on the road and ppl think I'm crazy for swerving to miss a 1inch pothole, but it's not like I off-road this thing to jack up the alignment specs that badly after such a short period of time, any thoughts?
Old Feb 3, 2007 | 04:08 PM
ecorona6's Avatar
ecorona6
damit...I am considering some SPC rear cambers!!!
Old Feb 3, 2007 | 04:12 PM
MIAPLAYA's Avatar
MIAPLAYA
Can you please point out the "other" toe bolt. I agree there are two eccentric bolts on the rear but only one of them adjusts the position of the spring bucket thus adjusting the toe... The other one is for camber adjustment and is how you adjust camber with factory arms. Moving this is not going to fix your toe settings. I've been dropped 1.5" since almost day one with this car and my camber and toe have never moved themselves that far out of alignment with the SPC kit.
Old Feb 3, 2007 | 04:13 PM
Armando's Avatar
Armando
Damn, I was about to order the spc kit too. Any better alternative camber kits out there? Anyone?
Old Feb 3, 2007 | 04:14 PM
MIAPLAYA's Avatar
MIAPLAYA
Not for the money. There's nothing wrong with the SPC setup. I've had it for over 2 years and never had a single issue getting my car to the proper settings and keeping it there. Neither have the other 10 SD guys who have the same setup..
Old Feb 3, 2007 | 05:25 PM
Z1 Performance
Former Sponsor
he's talking about issues with the front arms, not the rears
the fronts are actually being redone from what I understand
there is no better kit, at ANY price, for the rear alignment of a Z, than the SPC.
Old Feb 3, 2007 | 05:27 PM
ecorona6's Avatar
ecorona6
Ok...cool...I need your payment info.
Old Feb 3, 2007 | 05:33 PM
Z1 Performance
Former Sponsor
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
