Changing hub assembly, torque specs?
Old Feb 1, 2007 | 05:57 PM
Fingers's Avatar
Fingers
Default Changing hub assembly, torque specs?
I was wondering if any of you guys knew the torque specs for the four bolts that hold on the hub assembly. I was able to find the torque specs for the brake calipers by searching here but I couldn't find anything for the hubs. I know some of you guys have done this and I want to know if you had any problems fitting the torque wrench in the wheel well area, I may be pressed for space if I can't get the car high enough off the ground and have to come in from the top. Also does anyone know where I can purchase a service manual, I would like an actual book and not an e-manual.
Old Feb 1, 2007 | 06:31 PM
Kolia's Avatar
Kolia
This might help ?
Old Feb 1, 2007 | 06:41 PM
Fingers's Avatar
Fingers
Thanks, if I'm looking at that correctly its 58 to 72ft-lbs, hopefuly I won't have any problems getting the torque wrench back there. Thanks again I'll be changing my right front tomorrow.
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
