06 ZR 1st suspension mod
I want to add mods to suspension peice by peice as money allows. Obviously money is an issue. I would like my ZR to handle as well as possible and still keep as much of its street character as possible. I do on on occasion drive the car very hard as I am close to the Dragon and like roads. Any help in making choices for modifications are appreciated. If you would also give your reasons why you recommend it would be helpful.
TIA
TIA
Well, i have the nismo suspension and sways - not quite sure the effect it would have installing the sways on stock suspension( I assume the same as with the nismo suspension), but i know when i had both installed, the sways definitely reduced body roll. Feels like the car is on rails now. I love the set-up although i wouldnt mind a more aggressive drop. but then you start dealing with camber issues and what not, so i decided to go with the nismo set-up.
Happy modding!
Happy modding!
You should check out the Hotchkis Sway bar, I have them on my car and they have improved the handing alot.
http://www.forgedperformance.com/sto...cat=306&page=1
Hope that helps
Matt
Hope that helps
Matt
Originally Posted by Sunset350ZR
Well lets do it like this then. How will a set of Nismo sway bars do to an otherwise stock suspension.
Rich
Tochigi_236
Sep 27, 2015 03:40 PM
